Old 04-25-2015, 06:56 PM   #1
EMS-HW50C install
Just finished installation. After looking at different locations decided on shelf above power panel. Am going to build a shelf with a front panel to hide unit. Should I be concerned about heat build up from the unit.
ID:	75222   Click image for larger version
2011 Georgetown 337 2011 Chevy Impala
pakkdad is offline   Reply With Quote
Old 04-25-2015, 07:23 PM   #2
Firefighter969's Avatar
The EMS has no reason to build up heat that I know of myself. Mine is behind my fuse panel in the back wardrobe closet.
2000 F250 Superduty CC LB 7.3 4x4
2013 344QB Wildcat
Nights camped 2014 ( 15)
Nights Camped 2015 ( 4 )
Firefighter969 is offline   Reply With Quote
Old 04-25-2015, 07:38 PM   #3
I asked this question on another thread, however do you hear a slight hum from your unit when plugged in? Thanks
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 04-25-2015, 07:43 PM   #4
Yes a slight hum.Was thinking about insulating the space when I make a cover. That's why I wondered about heat.
Old 04-25-2015, 08:17 PM   #5
VinceU's Avatar
The hum is normal comes from contactor which conducts power till opened by a fault. You can ventilate the shelf with holes top and bottom kept out of sight.
Old 04-25-2015, 09:45 PM   #6
I didn't secure EMS to anything. It's just on the floor in the compartment behind the converter, under the refrigerator. The 10-2 wire is pretty stiff and doesn't let it walk around.
I had the converter out today installing a new DC circuit. While I was in there I looked at securing the EMS to the inside wall. I didn't see any way to screw it down. Are there holes inside the case?
Sent from my phone using Tapatalk.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 04-25-2015, 09:52 PM   #7
Mine has 4 holes around the base. 2 are kind of hidden by the wire clamps.
Old 04-26-2015, 04:35 PM   #8
I'm pretty happy with my installation! The EMS detects power flow at 1 amp, which happens when I power up the television and satellite receiver. The only thing that surprises me is the fact that the remote display flashes constantly, I would have thought one would need to press a button for display to work!
Old 04-28-2015, 07:00 PM   #9
That's the reason I put my display unit in a cabinet. That flashing display would drive me crazy if I could see it all the time. I figure I really only need to look at it if the power is mysteriously off or I want to see my voltage and/or amps, which should not be that often.
2015 268RKS Vibe Xtreme Lite
2012 F-150 EcoSCREW Max Tow
tmhudg is offline   Reply With Quote
Old 04-28-2015, 09:44 PM   #10
Mine is mounted to the front of the power panel near floor level. I was contemplating a mini-project of moving it but, now that you mention the flashing, it may be best to leave it where it is. I can see it when I need to by stooping down.
- 2000 Coleman Mesa
