Old 01-24-2015, 05:14 AM   #1
Bradlo3's Avatar
Enclosing the under belly
Would appreciate any advice on enclosing the under belly of a Grey Wolf 28BH. We like to camp year round and believe this would help insulate and protect.
Bradlo3 is offline   Reply With Quote
Old 01-28-2015, 03:45 AM   #2
I used a home wall insulation, it comes in 4◊8 sheets, foil side up, white side down, it's a 3/4 foam insulation. I used it to replace the plastic under belly cover, due to leaving the black tank flush on and flooding, actually ripped off the cover. Just a FYI NEVER LEAVE WHEN YOU FLUSH BLACK TANK. It was very stupid of me.
jimmyt11664 is offline   Reply With Quote
Old 01-28-2015, 08:28 AM   #3
kerrlakelover's Avatar
I agree with the home insulation. If your TT currently has no belly pan whatsoever, you can pick up 4x8 sheets of the black corrogated plastic (corroplast) from a plastic retailer. I just picked up a sheet for $20 locally. ($20 may have been a sweet deal since it was her last piece in stock.) While the manufacturer uses 1 solid piece, I don't see why you could not use sheets if you install it correctly. You may have to install some additional cross members (2x2 wood or angle iron) to attach it to. Then use the same kind of self tapping screws with washers that the manufacturer uses.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 01-28-2015, 12:39 PM   #4
Anyone have pictures of their install of insulation or corroplast?
dcarver1987 is offline   Reply With Quote
Old 02-03-2015, 10:57 AM   #5
How do enclosed underbellies work when you're going over rough roads?
Ash and Jim
and Wee Dram the Westie
2014 Rockwood HW276; 2008 Ford F150 V8 5.4 ltr. King Ranch
AshnJim is offline   Reply With Quote
Old 02-03-2015, 12:00 PM   #6
arpipeliner's Avatar
The plastic kind tuck inside the I beams and rest on that. Mine is screwed into a metal brace on front of the camper and then put the next piece on top of the ending of the first piece like shingles. The factory has 2" wooden slats where metal braces were not present. Three to four screws across each seam. It's held up great. If worrying about sagging just and another slat in the middle.
arpipeliner is offline   Reply With Quote
Old 02-03-2015, 12:26 PM   #7
Not sure what/why you mean by rough roads. Unless you are 4 wheeling in the mud with deep ruts, the underbelly will be fine no matter what type road you are on. I would say that if you are on a gravel road, the belly would provide some protection for your mechanical stuff that is otherwise exposed.
"Old water skier"
