Old 11-01-2012, 07:20 PM   #1
Don't Camp Enough
DSMURPHY's Avatar
Equilizer Bar Storage
I have gotten a ton of great ideas and information from the forum and I would like to share this simple mod with other Jammers and Equalizer owners.
My old 8314SS had pass thru storage in the front. I installed a 3" PVC tube with an end cap just long enough to hold my bars. This setup kept the bars out of the weather and not banging on something else.
When we traded up to the 3008W, it didn't have appropriate space in the under bed storage area to remount the tube.
I purchased a PVC cap and threaded end. With 1/4 / 20 threaded rod and 1 1/2" wide strap, I mounted the tube to the front of the TT as you can see in the pictures.
The tube is just long enough so that the bars do not rest on the threads and not so long that the bars go too deep into the tube.
Now I don't have to store the bars in the truck, the garage or out in the open at a campground.
ID:	21289   Click image for larger version
ID:	21290   Click image for larger version
'2016 Rockwood 8288WSA
'2010 Tundra
DSMURPHY is offline   Reply With Quote
Old 11-02-2012, 08:23 AM   #2
Herk7769's Avatar
Sweet idea. I like the attachment design as well.
HAM CALLSIGN - KC3FFW
Old 11-02-2012, 08:26 AM   #3
Wanna Be Camper
SaskCampers's Avatar
Nice idea.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 11-02-2012, 08:41 AM   #4
punkaccountant's Avatar
Great idea! Is it the angle of the picture or is your L Bracket tilted back a little bit? The reason I ask is I can't get mine to stop from moving. I always tighten the bolts to the recommended torque and by the time I get to the campground the brackets are tilted again.
http://www.forestriverforums.com/attachments/signaturepics/sigpic20864_3.gif
2013 Rockwood Mini-Lite 2306
2011 Ram 2500HD Hemi
punkaccountant is offline   Reply With Quote
Old 11-02-2012, 08:49 AM   #5
Here is how I stored & locked mine.
Name:	Torsion Bar Holder 1.jpg
ID:	21297   Click image for larger version
Name:	Torsion Bar Holder 9.jpg
ID:	21298   Click image for larger version
Name:	Torsion Bar Holder.jpg
ID:	21299   Click image for larger version
Name:	Torsion Bar Lock.jpg
ID:	21300   Click image for larger version
Name:	Spring Bar Handle In Place.jpg
Old 11-02-2012, 09:01 AM   #6
dfskinner's Avatar
Good idea..... I like the use of the PVC pipe. Only suggestion would be to paint it black to match your trailer.
Other than that looks great...... our older trailer had more storage area than the new one... one thing is I've gotten better at packing, so I think I"m using the space I have better than in the past where I just loaded up everything.
dfskinner is offline   Reply With Quote
Old 11-02-2012, 09:06 AM   #7
Don't Camp Enough
DSMURPHY's Avatar
Mine have always moved some. I have had my Equilizer since '06 and have considered the bracket adapters offered by the company to let the bars slide more quietly. However, I read also that they would reduce the sway control somewhat. So, not for me.
The brackets always seem tight when I check them and the noise they make let me know they are working.
'2010 Tundra
Old 11-02-2012, 10:05 AM   #8
AquaMan's Avatar
Nice mod. Will let my buddy know about this one. One thing you might consider, just as a precaution, put a screw through your hang strap just to make sure it doesn't get bounced out while going down the road.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 11-06-2012, 10:04 AM   #9
easy fix to stop the brackets from moving ...drill 2 small holes on either side of the bottom bolt and put a screw in each . thus making a forward and backward 'stop' for the bottom bolt of the bracket. It worked great for me .
I also bought the nylon noise stopper and it didn't really hinder the sway . No more than adding grease.
harley4275 is offline   Reply With Quote
Old 11-28-2012, 09:49 PM   #10
Don't Camp Enough
DSMURPHY's Avatar
Equilizer Bar Storage -Update
Thanks to dfskinner and ttrost65 for your improvement suggestions.
I wanted to post a picture of the improved look.
Name:	Paco 11-2012 005.jpg
'2010 Tundra
