Old 06-07-2010, 07:44 AM   #1
archham's Avatar
Extending the Shower Hose
In our shower (inside) the hose is about a foot or so too short for me to use. What is the best way to extend this? Are longer ones available?
2012 Puma 30FQSS
2005 Ford F-250 Super Crew 6.0 PSD
2003 Honda Odyssey
1 wife, 1 son, & 1 cat
Volunteer Firefighter/EMT
Asst. Scoutmaster (BSA)
archham is offline   Reply With Quote
Old 06-07-2010, 08:42 AM   #2
NWJeeper's Avatar
Remove it and take it with you to Home Depot or Lowes and see if you can get a longer one. I believe the fittings on the ends are standard.
Ed & Wendy
www.nwjeepn.com
Old 06-07-2010, 07:47 PM   #3
Cunning Linguist
Yep ...
Cut the existing hose in half.
Cut a 1" piece off one of the halves.
Take it to Home Depot, Lowes, ACE, etc so you can match the size.
But replacement length of bulk hose off reel, or buy same ID/Od Tygon clear tubing in whatever length you need.
Buy two 1" concentric slip couplers in pvc/plastic, copper/brass or stainless (think they are 3/8" OD)
Slip the couplers into the ends of the existing hose end the jumper & seal/tape joints if needed (may not be nessisary to seal with the internal couplers, since you should only be working about 40 PSI pressure).
Acara is offline   Reply With Quote
Old 06-07-2010, 11:14 PM   #4
Also wont hurt to replace the peice of crap shower head you will much happier with a better shower head
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 06-08-2010, 04:28 PM   #5
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I replaced mine with one from Lowes. It's a residential style one with massage head and longer hose. I havea seasonal trailer...so shutting of the flow on the hose isn't an issue. (I have no gray or black tanks) You can see pics in my gallery.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 06-09-2010, 03:00 PM   #6
Oxygenics Shower Head!!!
Nights camped in 2010 = 21 nights
2008 Chevy CCab 5.3L 4WD Z71
2008 FR Surveyor 291
Champion Genset
Slpybear, Mrs Slpybear, Three Cubs
slpybeartx is offline   Reply With Quote
