Old 09-05-2018, 10:43 PM   #1
sawpdx's Avatar
External propane connection
Has anyone been successful connecting a standard Coleman 2 burner camp stove model 5430E to the external propane quick connect?
sawpdx is offline   Reply With Quote
Old 09-05-2018, 11:37 PM   #2
RV There Yet?
IsleDog's Avatar
I think the issue you are going to run into is that the stove is high pressure and has no regulator and the quick connect is probably low pressure, meaning it is after the regulator.
IsleDog is offline   Reply With Quote
Old 09-06-2018, 05:49 AM   #3
You will need to remove the regulator on the Coleman stove. The quick connect on the camper is low pressure. You cannot have a appliance with a built in regulator connected to to a low pressure line.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is online now   Reply With Quote
Old 09-06-2018, 06:13 AM   #4
jeff64's Avatar
X2
Good of description as any. Don't believe you can do it. You can get a hose that will go from the stove to your bulk cyl. You probably know that!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 09-06-2018, 01:42 PM   #5
sawpdx's Avatar
Is there a brand name camp stove other than Colman that will easily connect to the quick connect on my 5th wheel. Apparently Coleman uses proprietary fittings and I can’t find the right sizes to adapt this stove to use the quick connect.
Old 09-06-2018, 01:59 PM   #6
Look at the Camp chef stoves they all can be run off your LP quick connect except there mtn series with this hose.
https://www.campchef.com/rv-connection-hose.html
dan4jeepin is offline   Reply With Quote
Old 09-06-2018, 02:00 PM   #7
A couple of options here.
propane
