Old 01-02-2018, 12:32 PM   #1
External Wifi Antenna
Hi all. I have purchased an Alfa Wifi Camp Pro set. I am planning on mounting the external antenna on a painter's pole. My question is about the best place to route the antenna wire outside. Would prefer to not to have the wire dangling outside the trailer when not in use. Any suggestions? I have a Rockwood Mini Lite 1905.
mbtraveller is offline   Reply With Quote
Old 01-02-2018, 04:33 PM   #2
Fulltime family RVer
Across the roof and in the fridge vent.
ependydad is online now   Reply With Quote
Old 01-02-2018, 06:51 PM   #3
Thanks. I'll think about that.
Old 01-03-2018, 11:40 PM   #4
When you get it set up and running, will you kindly post how well it works. I am looking for a better wi fi experence, trying to learn as much as possible. Thanks. Jay
Jay2504 is offline   Reply With Quote
Old 01-04-2018, 12:05 AM   #5
Phat Phrog Stunt Crew
elind's Avatar
I attached mine on my TV antenna and then run it down my bedroom vent. Then I mounted the Router on the bedroom TV bracket.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 01-04-2018, 12:30 PM   #6
Thanks for that. I think that I am going to try routing the antenna wire from the kitchen table, past the hot water tank, and outside the trailer through the water filter access panel. The painter's pole will be supported by a piece of pvc pipe that will be clamped to the rear bumper. When it is time to move I can unscrew the antenna from the painter's pole and store it in the filter compartment. The pole can be thrown in the back of the truck. At least that is the plan for now. Too cold to do anything here until we head south.
Old 01-04-2018, 12:31 PM   #7
Will do.
Old 01-04-2018, 12:46 PM   #8
We fulltime and I need quality internet for work (M-F at a 9-5) so I might have higher needs/expectations than most.
When we went fulltime, I bought a WifiRanger with external antenna to help boost wifi signals. Within about 6 months, I unplugged the external antenna as I never use the WifiRanger to pull in wifi signal from RV parks/campgrounds.
The reason is that while you can use it to get a better connection to the campground wifi, it's almost always crappy internet behind of it. You're limited by the overloaded network and slow speeds that the RV park pays for.
I can count on one hand the number of times in the last 2 1/2 years that I've used RV park wifi and that was only because cell service was non-existent in those areas.
Old 01-04-2018, 01:06 PM   #9
geezer with gadgets
757Dave's Avatar
Ependydad, I don't want to hijack the thread, but I would like to know what you use for your wifi service. Carrier, plan, etc.
Apologizes to the OP!
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57
757Dave is offline   Reply With Quote
Old 01-04-2018, 01:07 PM   #10
Thank you ependydad, for the info. We aren’t full time by any means and I don’t work from “home” like yourself. Mostly both of us will surf the net on I pads in the evening. Are you recommending that I get better cell service and use that? Right now we have a cellphone data limit.Please forgive me for not being too tech savvy. Jay
antenna
