03-19-2009, 10:04 PM
Extra backup lights for trailers
I needed a way to get extra light behind my trail to help me back up into spaces at night. Even though my wife assists me with a FB radio, it helps to have that extra light. I bought a pair of off road lights used on sand rails and such. I mounted them onto the frame on each side and wired them to the backup light circuit so they only come on when I back up. They adjust up and down so you can get the coverage you desire.
03-19-2009, 10:16 PM
Back Up Lights
Neet idea! I will be adding a set to my TT. I do have one question, are those concrete concrete blocks.
Life is something to do when you've finished breakfast
Chuck & Margie
Both Retired
08 2500HD Silverado 6.6L Duramax
Flagstaff 829fkss
03-19-2009, 10:46 PM
They almost look like the footings used when you build a deck on a house.
Nina
Bob & Nina's Bunkhouse
2003 R-Vision Trail Bay 26 BH
Add In: Sarina (15), Susan (11), and dog Midnight.
Hitched up to a White 1998 F-150 Ext. Cab
with a Hayes brake controler and Robin sway control
03-20-2009, 12:35 AM
Yes, they are concrete pier blocks. Due to my yard having a slight slope, I use them to split the difference when putting my back jacks down. This way it keeps them further apart instead of fully extending them down with less stability. Only use them at home. I will be getting the area graded this summer and fix that slope problem.
03-20-2009, 08:53 AM
Moderator
Talking about back-up lites......my Surveyor came without backup lites, but my Trailmanor had them. I guess there is no industry wide standard??
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
03-20-2009, 10:14 AM
Where did you tie into the backup circuit?
I bought my lights last with doing the idea of doing the same thing. The only place I knew to tie in was up front where the TV harness wire connects the trailer. I was also going to put in a 30 amp relay with the backup circuit as the activator.
David
Devils Tower 2008
The Hunts
99 Tahoe 5.7L; 3.73; Tow Pkg; 2nd Tran Cooler; Towing Fan Clutch;
Throttle Body Spacer;Fram Air Hog Air Intake; FlowMaster SUV 50;
MGSCustom ECU tune [ new HP rating of 300 ]
Equal-i-zer Hitch
2009 Flagstaff V-Lite 30WRLS
1982 16' Glastron Ski boat
03-21-2009, 12:11 AM
Locate the pin on the connector that operates the back up lights. Follow your TT connector back to a metal box attached to you trailer tongue, usually just under the front of the TT. Open the box and find the wire associated with the back up light pin using a lighted tester pen. Make sure your parking brake is on and wheels choked when you put your tow veh in reverse. By removing the wire screw caps, you will eventually locate the right wire when your pen lights up. Tap into that wire and put the screw cap back on. Run your new wire out of the box and close it up. Now you have your lead for your back up lights. Just don't forget to ground each light as well.
03-23-2009, 10:07 AM
That is where I was thinking. I wanted to make sure there was not a better place.
David
Devils Tower 2008
The Hunts
Equal-i-zer Hitch
03-23-2009, 10:36 AM
If you have the standard 7 blade plug it will be the only one not being used.
03-29-2009, 08:04 PM
Hi,
Thought I'd chime in on this one. I'll be putting back-up lights on soon as well. I don't want to assume that all Forest River wiring is the same, but on my Rockwood the wire I need to use is the yellow wire. It is the only one not connected to anything inside the junction box.
 Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd, Driver: Clint
Navigator: Melanie
Entertainment: 3 Boys (19,17,15), 2 dogs (1 Basset Hound, 1 Great Pyrenees) and now 2 Canaries.
Mission Statement: Just another adventure!
2009 Roo 19
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 328 |
| 34 members and 294 guests |
| acadianbob, BelgianSquiggy, buzzmonster, caper, Char_n_Kath, donn, Douglasdh62, GaryRudolph, GASPEDDLER, herk7769, Iggy, Itsthetwoofus, JDWeir, JFM-jr, jsutherl, Laura, leencharlotte, leomosley, Linnemj, martin73, mckirby50, Newellri, RayJae, RED Baron, reliefman, rerger, rkswyo, Rod Johnson, Shelley4832, skgeorgy, slipf18, Terier, tucket, wvcampers |
| Most users ever online was 881, 06-22-2011 at 11:07 AM. |
