Old 10-21-2015, 11:38 AM   #21
tlambert's Avatar
Originally Posted by Rbertalotto View Post
I did not use the back up light activation feature. I hardwired the monitor to a switched 12 V lead. In this way I can turn the monitor on anytime I want. But the cameras on both the truck and the trailer are wired into the running lights . They afford to turn the cameras on I need to have the running lights on. This is no big deal for me as I drive with the running lights on all the time. I want to be visible.
That's what I wanted to know.
So do you think having it wired so it doesn't have to have the lights on would be any problem?
The monitor has it's own on/off switch right?
My truck is 2011 Silverado and came the factory backup camera.
I just want to be able to check out what's happening at the end of the camper while traveling.
Tim
Tim
tlambert is offline   Reply With Quote
Old 10-22-2015, 12:42 AM   #22
I used a wireliess backup camera from Magellan that mates into their aftermarket (some, not all models) GPS. Had used same on my truck for a backup camera. On the truck it is supplied by the backup light wire, so only broadcasts to the PGS when in reverse. On my class B, I didn't needs it as much but wanted one for my boat trailer to see backing up, so it is mounted by industrial hook and loop tape and wired to the boat battery, hence on all the time. I put a small switch in the add on module that attaches to the GPS, to turn that component on /off as needed so mostly have it showing GPS but can at any time see behind the boat trailer by flipping the switch. I think I'm going to get another camera for the back of the class B so I can see the motorcycle trailer when I'm pulling it and wire it similarly to see it whenever I want, even driving down the road.
That said, the system discussed here looks great for the $$, but I don't want another monitor as my GPS is a 7" size already.
Calgary, AB Canada
Ridenfun is offline   Reply With Quote
Old 10-22-2015, 02:59 AM   #23
Any way you give 12v power to the camera and the tv monitor will work. But grabbing power from a running light or the license plate light is the easiest method.
Rbertalotto is offline   Reply With Quote
Old 10-22-2015, 12:45 PM   #24
Gleaner's Avatar
the easiest method.
Mine showed up today.
Just wondering how you mounted your screen.......
Suction cup to the window?
2015 nights camped (54)
Gleaner is offline   Reply With Quote
Old 10-22-2015, 02:14 PM   #25
I had to get VERY custom to mount all my electrical "junk" on a relatively small dash area.
I moved the radio from the top of the dash to the bottom. Fabricated a panel and mount to move the new GPS up to the radio position so it would receive the GPS satellite signals better. In between the two I had a thin pocket that I fabricated a slide mount for the rear view monitor. When not in use, it lives in a "drawer". When needed I pull it out so it can be viewed.
Old 10-26-2015, 01:40 PM   #26
Gleaner's Avatar
ok.
Thanks.
I'm thinking of mounting it to a thick piece of UHMW..
Like I did my fishfinder in the boat.
Old 10-26-2015, 01:58 PM   #27
Here is the image I forgot to post to the above
Old 10-26-2015, 02:15 PM   #28
Gleaner's Avatar
Nice work.
Sadly, your dash is different than mine.
Old 10-27-2015, 11:15 PM   #29
Following.
bobneal69 is offline   Reply With Quote
Old 11-02-2015, 03:35 PM   #30
Rbertalotto
Is the video in color or BW? Thanks
Cedar Creek 38FB Ram 3500 Dually
bobsue1 is offline   Reply With Quote
