Old 12-16-2015, 04:01 PM   #41
Yes, simply glued up there
Rbertalotto is offline   Reply With Quote
Old 12-17-2015, 04:42 AM   #42
More details at the end of my blog here:
RVB Precision | Welcome to the world of ultra precision
Old 12-25-2015, 10:39 PM   #43
JPS0929's Avatar
Rbertalotto one more question Santa delivered today. Did you run power from the camera or the wireless transmitter. Not sure which one to connect to running lights or if it matters. Like I stated before I am a newbie any chance of a quick wire diagram? Any help is greatly appreciated. Merry Xmas
JPS0929 is offline   Reply With Quote
Old 12-25-2015, 10:48 PM   #44
I'm not sure I understand the question. I hope this helps.
The transmitter AND the camera both need 12v. I tapped into the running lights for this power. For the camera to work, the running lights will need to be on. But I run with lights on 100% of the time so this was not an issue.
For the TV monitor, I simply tapped into a switched circuit under that dash. In this way I cant accidentally leave the TV screen on and kill the battery.
Old 12-25-2015, 11:01 PM   #45
JPS0929's Avatar
Ok so I need to wire both the transmitter and the camera to the running light ? I wansnt sure if I could just pull power to one since they would be in line
Old 12-25-2015, 11:05 PM   #46
JPS0929's Avatar
I understand stand the monitor will be separate Does the receiver also with the monitor have to be wired to a power source or since they are connected can I just wire one to a keyed power source? Sorry I am just confused
Old 12-25-2015, 11:09 PM   #47
On my system, both camera and transmitter were connected together and then one power wire went to the light.
If your camera and transmitter have separate power wires, you'll need to tie them together and then to the clearance light power.
Old 12-25-2015, 11:17 PM   #48
JPS0929's Avatar
Ok I understand... Just wasn't sure if I had to tap both the camera and the transmitter Into the 12 v or just one since they were connected.
Old 12-30-2015, 09:55 AM   #49
BDavis's Avatar
Learjet, is that mounted to the little cup in the dash? Just bought the furrion and have a super duty as well
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 12-30-2015, 06:51 PM   #50
Learjet's Avatar
EZ Backup Camera Installation
Yes, i used the display back plate and secured it there.
It is blocked when in drive, ok when in reverse. Not a big deal for me, since i turn it off going down the road anyway.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
