Old 05-29-2016, 05:45 PM   #1
Stormrider151's Avatar
Fans in the fridge
I've seen several references to folks placing fans in their refrigerators to make them more efficient. I have a Dometic fridge and I did place fans on the inside which has helped some. But I have also seen where fans are placed in the back of the unit to increase the airflow. I was wondering what was used and how are they positioned in the unit? Thanks a bunch.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 05-29-2016, 05:53 PM   #2
Crusadernoob's Avatar
Computer case fans, I installed 5 behind our fridge, it helped tremendously. Maybe I can find some pics.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 05-29-2016, 06:03 PM   #3
Thank you. Pics would help a lot. Where did you get the power for them? I wired my inside fans to the 12 volt in the back by running the wires down the drain tube.
Old 05-29-2016, 06:05 PM   #4
I have pics in my mods but I don't know how to post them. I used the power from the fan that is already behind the fridge, ran a switch and mounted it next to my switches on the front panel.
Old 05-29-2016, 06:09 PM   #5
Which way did you point the fans? I'm guessing up towards the vent.
Old 05-29-2016, 06:14 PM   #6
Yes, my fridge is on a slide so I put 2 at the bottom vent pulling in and 3 at the top pushing out
Old 05-29-2016, 06:57 PM   #7
Thanks. I'll order some fans and get to work.
Old 05-29-2016, 07:22 PM   #8
X2
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
cfiowa is offline   Reply With Quote
Old 05-29-2016, 08:03 PM   #9
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
This duct has three 5" medium rpm fans blowing air out the top vent in a slide from a 4-door Dometic. Works fabulously. It was the first thing I did to this our 3rd RV. I actually disconnected the small "booster" fans that were installed 1/2 way between the vents.
XLR 415AMP, F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.
Heart issues-laid up for a spell
dwhit is offline   Reply With Quote
Old 05-29-2016, 10:08 PM   #10
My problem is access to the top of the fridge. Mine only has one intake vent at the bottom of the refrigerator. I'll have to find a way to mount the fans up high enough to get the air to the vent on top of the trailer. My fridge is located on the back wall of the trailer. That's a cool way of doing it though. Looks great!!!
fan, fridge
