Old 04-12-2011, 12:53 AM   #1
Fastening to interior wall
On our Rockwood 8315 BSS I would like to put a light weight shelf, not a cabinet, on the wall in the bedroom beside my wife's side of the bed. This would be so she can put her glasses and book on it when it's lights out time. It will be on the fixed wall of the trailer not the slide out. My side of the bed already has a small cabinet in place. I am thinking about 12" x 12" with vertical backing panels at 90 degrees to fasten onto both walls. I don't want to use screws to fasten it to the walls so I am wondering about using construction adhesive for the fastening. Any experience with this method or other suggestions? There won't be anything on this shelf when we are travelling.
Thanks,
Don
2010 Rockwood Signature Ultra Lite 8315BSS
2003 GMC Sierra HD Crew Cab
Duramax Diesel Power
DonJP is offline   Reply With Quote
Old 04-12-2011, 06:40 AM   #2
KyDan's Avatar
I don't know about glue. It might pull off the wall paper?
I have 2 photo picture frames mounted on my walls.
I used the shortest molly bolts I could find. They do require
holes. I hated to do that but the pictures are not going anywhere.
I guess your "vertical back plate" would spread out the load
and adhesive might be OK. I know you don't want to make holes
but gluing this on the wall is permanent just like holes and both
are going to leave permanent marks! Once the shelf is there,
it's going to stay there right???
Have you tried pounding the walls to feel for studs? 12" wide
isn't going to spread between 2 studs but with a back plate,
you could drill and screw into only one stud and still hold the
shelf. Just a thought. (Even if you drill a tiny pilot hole and miss
the stud, you can drill another until you find it. The holes
will be hidden behind the shelf back plate.)
You could even use adhesive and a screw to hold it
until the adhesive dries.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 04-12-2011, 07:45 AM   #3
Herk7769's Avatar
There are some new products out there that use "directional" glue tabs.
They stick like double sided tape, but "pull the tab" and it pops right off without damaging the wall paper. Might find something for her glasses but for a book, you will need molly bolts for hollow core walls.
Remember you are drilling into THIN Luan (maybe 1/8 in MAX) and then Styrofoam. That drill can "catch" on the Luan and plow right on through to the outside. If you are going to drill into these walls, invest in a set of "drill stops." They are metal collars that have a set screw to prevent a drill "runaway."
For pictures I use "Museum Putty" to keep stuff on the wall from flying off the wall. A small nail hangs it and the putty keeps it in place.
The Container Store > Museum Putty
HAM CALLSIGN - KC3FFW
Old 04-12-2011, 08:07 AM   #4
camping
tentcamper1's Avatar
would something like this work?
Shop 3M: Command Loft Shelf
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 04-12-2011, 09:25 AM   #5
Two cases of corona stacked on top of each other work perfectly. Or switch sides.
2009 Rockwood 8315BSS
1999 Chevy Tahoe
Pullrite Anti-Sway Hitch
nycamper is offline   Reply With Quote
Old 04-12-2011, 09:46 AM   #6
We have the same model trailer. We just put our glasses and paperback books up on top of the valances when it's time to call it a night.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 04-12-2011, 02:59 PM   #7
flyrotor's Avatar
Use a stud finder to locate the studs the same as you do with drywall, however if you don't have one just press firmly on the wall, where it gives there is no stud, be sure to drill it prior to inserting a screw (not familiar if your frame is wood or aluminum).
I agree, the glue will only be adhering to the wallpaper and would not last too long.
As for placing a screw... if the mod is an improvement, go for it, it's your trailer, enjoy it, it won't change any trade in value if it is done correctly.
As for the cases of Corona, maybe just the empty boxes, if not the shelf will get shorter and shorter and the beer is better really cold
flyrotor is offline   Reply With Quote
Old 04-12-2011, 03:08 PM   #8
wfmdfm's Avatar
We have used the 3m tabs for hanging stuff and it seems very strong. I think the screws would work fine also but I would try and locate a stud if you plan on any other weight. If you elect for the beer cases I would use Molson Golden.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 04-13-2011, 12:45 PM   #9
gregm59's Avatar
We use the 3M tabs, but have to be careful of the weight we put on them. We've found they can pull the wallpaper away from the wall if something too heavy is on them. This includes winter coats...
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
gregm59 is offline   Reply With Quote
Old 04-19-2011, 07:55 PM   #10
traveler
reinreb's Avatar
Hey you guys with 8315 BSS rigs, do you have any pictures of your rigs or campsites, I am waiting delivery of my 8315 BSS and my dreams could be enhanced with Kodak moments.
2011 Ram 1500 Quad Rockwood 8315 BSS.
"We travel initially to lose ourselves; and we travel, next to find ourselves. And we travel, in essence, to become young fools again- to slow time down and get taken in, and fall in love once more."
ó Pico Iyer
reinreb is offline   Reply With Quote
