Old 09-09-2014, 06:27 PM   #1
trdutch's Avatar
FF Fan install
To install the vent cover (edited) fan-Tastic Vent UltraBreeze,over the Fantastic Fan, I had to remove 4 of the sealed over screws that hold the vent to the roof to install the Clevis pin brackets.
I put a healthy glob or roof sealant on each hole,put down the bracket and installed the new screws.
I know I got a good seal cause sealant oozed from under the brackets and through the screw hole.
My question is do I need to go back and completely cover those brackets with a top coat of sealant.
I can do it tomorrow but ran out of daylight and didn't have a new tube with me
Thoughts?
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 09-09-2014, 06:42 PM   #2
I think you did something wrong,the MaxAir requires No removal of roof flange fasteners! Youroo!!
Old 09-09-2014, 07:27 PM   #3
trdutch's Avatar
My bad
The max Airs went on the other 2vents
For the fantastic Fan I used
Fan-Tastic Vent Ultrabreez
'78.....tents
Old 09-09-2014, 09:22 PM   #4
Canadian Member
itat's Avatar
FF Fan install
Youroo, here is a video of the Ultrabreeze vent cover he installed.
Trdutch, if you think the brackets might move you could add some Dicor to prevent that but it's not absolutely needed.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 09-10-2014, 05:43 AM   #5
trdutch's Avatar
Thank you
I'm pretty sure I installed it with more care than most shops
'78.....tents
Old 09-10-2014, 05:57 AM   #6
Just to cover my reply in post #2,he said he was installing a MaxAir cover! Then he Mod. the post # 1 to read about a Diff cover! Then someone else posted a install Vid.for the Mod.post! I still stand by my Org. post that No removal of fasteners or sealant in needed for( Max Air) cover installs! Youroo!!
Old 09-10-2014, 06:12 AM   #7
mud yapster's Avatar
I just got the vent cover and will be installing it as soon as this heat starts to go away. Thanks for the video it looks easy to install just have to remove some of the old sealant and then reseal with new.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-10-2014, 06:55 AM   #8
vinmaker's Avatar
I should do this mod. Sure is nice having a cover over the the vent.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 09-10-2014, 09:25 AM   #9
DaveSchwartz's Avatar
It is an easy install. I used a utility knife to cut the existing sealant under where the bracket was going to be and just rolled it off with my fingers. After removing the screw, glopped it up good with fresh sealant, screwed down the bracket and then applied more on top to basically restore the profile of the stuff removed initially. Took only about 15 minutes and that included moving the ladder from side to side (I don't have the rear ladder and there ain't ever going to be anyone walking around on the roof).
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
fan
