Old 06-23-2016, 09:01 AM   #1
J42
Fibergass work
Our 2015 Forester 3051S sustained hail damage to 2 roof vents. The hail was only marble size, so I was quite surprised to find holes and cracks in the vent covers.
I've purchased some fibergass cloth and resin. I am planning on covering the entire vent cover, rather than just repairing the holes.
I've never worked with fiberglass before. I've been watching YouTube videos, but would like to get some tips specific to this application.
Thanks in advance for any input.
J42 is offline   Reply With Quote
Old 06-23-2016, 09:11 AM   #2
SeaDog's Avatar
Would it not be easier to just replace the vent covers? I would check and make sure what ever the vent covers are made of will not be effected by the fiberglass resin.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-23-2016, 09:19 AM   #3
grumpy0374's Avatar
I've worked with fiberglass, both mat and cloth. If you are doing it for the first time, it's messy, and hard to get it right unless you've had practice.
Vent covers are cheap, and you'll spend almost as much for material as new covers.
And, it's much easier to just replace the covers than it will be to get a good looking finish with the fiberglass.
Just my .2 cents.
Grumpy
Steve & Cheryl + Charlie & Zoey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
grumpy0374 is offline   Reply With Quote
Old 06-23-2016, 10:39 AM   #4
As said in the other post, the covers are cheap. If you decide to go with the fiberglass, clean your vent real well. You might want to rough the surface up with a piece of sand paper slightly.
You can cut the cloth to the size you are going to use.
Wear disposable latex gloves.
Mix the hardener and resin and stir well. You can use a wood paint mixer for this. A small amount goes a long way.
Make sure you put something under and around the area you are going to work. Coat the area with the resin./hardener mix. {a cheap throwaway brush would be good for this}. After the area has been coated apply the cloth. After the cloth is in place you can put another coat of resin/hardener on to soak the cloth real well. The cloth will sometimes stretch so it might now be too large for your work area. You can use a sharp knife to trim it down after it dries if needed.
After this sets up you can put another coat of resin/hardener on if needed.
Drying time depends on the temp outside and the amount of hardener used along with how well you stir the hardener and resin.
You will need several brushes, gloves and containers to mix in. The stick you use to stir can be used again as long as it didn't get dirty.
Done right this should last a long time.
It should work fine. Good luck!
Wattsworld is offline   Reply With Quote
Old 06-23-2016, 10:52 AM   #5
shughey00's Avatar
How about the fact that you have a very nice 2015 Forrester and you want to goober it up with a hacked fiberglass job on your vents.
Sorry man I am not seeing the logic of this on a 70k RV. It will look like crap. Even if by some miracle you are able to do the job cleanly ( highly unlikely first time)...it will look like crap.
If you are just doing this as a temp repair though ( you did not specify so I assume this is a temp repair) then go buy some Eteranabond Tape and make a simple temp repair until you can buy new vent covers.
I have worked with both types of glass matt over the years and it can easily turn into a gobbered up mess. Maybe on a beater 1984 MH but not on sweat ride like a 2015 Forrester.
Like I said if this is simply a quick fix then remove the covers and work on them off the roof at least. Again I will have to assume this is just a quick fix...even then I would opt for Gorilla Tape even over glass work.
Sorry but I am having a Whiskey Tango Foxtrot moment on this..:-)
2004 Cedar Creek 34CTKS heavily customized
2006 Ford F350 FX4 Lariat Dually w/tow boss
1999 Lance 1110...cause it's easier for short trips.
shughey00 is offline   Reply With Quote
Old 06-23-2016, 11:18 AM   #6
bubbles's Avatar
Universal vent lids are around $10.00 and direct replacements probably start at around $15.00 and easy to swap out. Being as though the fiberglass solution will cover up the existing lid it may not stay attached to plastic when travelling without additional rivets etc. I would opt for new lids and if not made of a shatter proof material (lexan etc.) add a vent cover so this issue would not happen again. Pay me now or pay me later. JMO
Old 06-23-2016, 11:28 AM   #7
Just replace the vent cover.
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
Old 06-23-2016, 11:48 AM   #8
Pickin' & Campin'
I am confused as to whether your vent lids are damaged or if it's your vent covers?
You said you had damage to the vents but also said you were going to repair the covers.
If you are referring to the OEM lid, then hail damage is not uncommon. They are thin and break easily, especially if they've been out in the sun for some time. (brittle)
If you are referring to actual vent covers (MaxxAir/Camco/Etc.) then I too am surprised they were damaged by hail as they are pretty tough.
Either way (lid or cover) I'd replace rather than repair with messy fiberglass.
If your lids are broken and you don't have covers.... get new lids and install covers.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-23-2016, 12:05 PM   #9
I've worked with fglass and it sucks. Mainly repairing a few old boats I used to have. Makes a big mess, can't get it off of you and it looks like hell when you're done (unless you're a pro).
You'll probably end up with fiberglass all over your roof before you're done.
I wouldn't recommend it.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 06-23-2016, 12:06 PM   #10
Croaker's Avatar
It would be best to remove the covers and glass them in your garage.
When you are done playing with the fiberglass, then you can do the sensible thing and buy new ones.
Croaker is offline   Reply With Quote
gas
