Originally Posted by mwdilday
I guess you would have to run a 15 amp circuit?
I highly recommend that you install a dedicated 15 amp receptacle on a dedicated circuit, especially if running it for extended periods. The problem isn't with the RV type receptacles, it's that sometimes the factories improperly connect the wires onto them and compromise their current carrying capacity.
Running the wiring may or many not be straightforward depending on where the panel is. Wiring can be run all over the place and 100% concealed though if you take the time to scope out a route and have the patience to fish wires. I've run all sorts of wiring all over in our TT.
If you don't have a breaker space left in the panel, you can get a tandem breaker that fits in the same breaker space.
Note that the mounting location needs to take into account the required safety clearances.
