Old 06-21-2012, 11:54 AM   #11
Originally Posted by Len & Cheri View Post
Great job! Might have to steal that idea
This pole will support a 3x5 flag and a second flag can be added, but it would have to be one that is the next size down. While at Pirateland in Mytle Beach I had a small pirate flag under Old Glory and I had another idea and that was to run a set of "red white and blue" rope lights up with the flag.
I used: a 1900 cover plate from an electrical box for the base support, to support the bottom of the pole, this was use also to extend the pumper, I used a ladder support from an above ground pool to keep the bottom from moving, then the pole is an 18" painters pole, I attach a pully on the top and used 3/16 nylon rope, two small brass clips and tied the two open ends of the rope to each clip, this was done so that I was able to add more then on flag, then on the very top of the pole I installed a plastic soft ball and used the threaded part of the pole and screwed the plastic ball in place then cut off the end of a paint roll handle and secured the ball to the pole. I did paint the plastic ball gold but it didn't hold up.
When it is time to pull out all I do is remove the flag, lower the pole and tie the rope around the ladder and put the access rope in the bumper cap. The pole stays on the camper.
Old 06-21-2012, 10:47 PM   #12
Jiggy's Avatar
Originally Posted by jsilvius
I place my flag in the arms of the Awning.
"old Glory" is flying higher of course.
Do you strap it in the groove of the arm? And do you use a longer flag pole?
2003 GMC 2500HD DMAX
2008 Yamaha Raptor 700R
2012 Forest River Shockwave 24FSMX
(2012 nights camped:10)
Jiggy is offline   Reply With Quote
Old 06-21-2012, 11:35 PM   #13
GASPEDDLER's Avatar
I bought my mount and pole from Poles and Holders - Your place for Flag Poles, Flags and Mountings
It will support 2- 3x5 flags and the whole set-up packs away neatly in a nice bag (included) that fits in one of my storage compartments.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 06-22-2012, 08:12 AM   #14
IT Guru
Send a message via AIM to jsilvius Send a message via Skype™ to jsilvius
I use two velcro straps and strap them in the groove, then wrap my rope light over them as well.
The flag kits I get came with two interlocking poles and mounting brackets. I use the two poles and the bracket on the "Stars & Stripes" and use one pole and the bracket on my Army flag.
I'll see if I have better picture of the setup and post it if you'd like.
2006 Flagstaff 831FKSS
2005 Dodge Ram 2500 SLT 5.9L Turbo Diesel Quad Cab
1 - DH (me); 1 - DW (Tee); 1 - DS (Jarod, 12)
Nights Camping: 2010 - 15; 2011 - 7; 2012 - 9
jsilvius is offline   Reply With Quote
Old 06-22-2012, 11:23 AM   #15
lindy's Avatar
I use a 25' flag pole from LOWES, it comes in 5, 5' sections. I made a base plate for the pole that goes under the tongue jack, then a vertical support that hooks into the hitch. The pole also doubles as a UHF Antenna pole. Pics to follow once I take them if any one wants.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 06-22-2012, 02:36 PM   #16
crushor's Avatar
Absolutely on the pics. I got a flag mount that I have have literally thrown together. It will work but not the greatest. Looking for better ideas.
2007 Ford F250 4x4 Harley-Davidson Powerstroke
2006 Cedar Creek Silverback - 35 LRLBS
(2012 -11) (2013 - 10 so far)
crushor is offline   Reply With Quote
Old 06-22-2012, 09:26 PM   #17
golfmedik's Avatar
I use a couple of clamp on, stainless steel fishing rod holders from Walmart. They are easy to put the ladder and can be mounted in just about any angle. They are around $35. But can be taken off in under a minute and stored very easily.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 06-30-2012, 07:42 AM   #18
lindy's Avatar
flag pole mount
The flag pole came from LOWES, was 5 each 5' sections. I welded a piece of exhaust pipe that was 1/2" bigger in dia. to the base, then slid a piece of exh pipe snug over flag pole, bolted thru all 3 and then filled the void between the 2 pieces of exh pipe with dense caulk.
ID:	15886   Click image for larger version
ID:	15887   Click image for larger version
ID:	15888   Click image for larger version
F.R.O.G. member
Old 06-30-2012, 09:49 AM   #19
GASPEDDLER's Avatar
Awesome
Equalizer E2 Hitch
Old 06-30-2012, 04:13 PM   #20
Jiggy's Avatar
Yeah If you don't mind looking for an up close pic of the way you did it. I'm not mechanically retarded but I don't want the wind to take it down. We have some high winds where we go camp sometimes.
led pad
