Old 02-29-2012, 04:16 PM   #1
Flexco Steps on 12 8528RKSW
Flexco steps use 8 Aluminum pop rivets as pivots on our new 5ver. I drilled them out and replaced them with 5/16" grade 5 bolts with locknuts and added a thin flat washer between the step pivot and frame on all steps. Also added an angle iron brace from the step frame(front) to the frame and one from the step frame(rear) to the frame crossmember for the axles. Can't believe anyone with any common sense would use alum pop rivets as pivots for steps. FR really dropped the ball on that one. I will eventually replace the bolts with steel bushings and bronze sleeves to get a more precise fit on the pivots. The addition of the braces sure took a lot of the bounce out of the steps.
Old 02-29-2012, 06:43 PM   #2
PapaSmurf's Avatar
We have Flexco steps on our Silverback, my first impression was cheap and flemsy. When I lifted the steps to leave the dealer, I told my wife I did not like the cheesie feeling steps. I would be willing to leave a couple of rolls to toilet paper at home, if needed, to free up weight for better steps.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
PapaSmurf is offline   Reply With Quote
Old 10-03-2014, 02:14 PM   #3
Krusing Since 1975
skydoctor's Avatar
Send a message via Yahoo to skydoctor
I had the same problem but, I called Flexco direct in Elkhart and they now have a retro kit that they will give you free to take care of that problem.
Hope this helps.
Contact
  • P.O. Box 1582
    2415 Bryant Street
    Elkhart, IN 46515-1582
  • Phone: 574.294.2502
  • Fax: 574.294.1734
  • Email: info@flexcoproducts.com
skydoctor is offline   Reply With Quote
Old 10-08-2014, 06:36 PM   #4
Hope this helps.
Contact
  • P.O. Box 1582
    2415 Bryant Street
  • Fax: 574.294.1734
What issues does the retrofit kit help with? The flexing issue or the aluminum pop rivets?
2014 Rockwood 8280WS
2010 Tundra 5.7 Dbl Cab 4x4
ronb707 is offline   Reply With Quote
Old 10-08-2014, 07:18 PM   #5
MC9
One of my pop rivets let loose. Whipped down to TSC and replaced all with 5/16 bolts. I feel better.
MC9 is offline   Reply With Quote
Old 10-21-2014, 01:14 PM   #6
Krusing Since 1975
skydoctor's Avatar
They allow you to replace the cheap pop rivets with ss nuts and bolts.
