Old 08-27-2013, 08:53 PM   #1
LKicklight's Avatar
FM Radio Antenna's
Our Crusader 270RET has two FM Radio's. One is in the bedroom that is part of the AM/FM/CD Player, the other is in the RCA Radio which is part of the entertainment center in the main cabin. While at the Crusader Factory a few weeks ago, the antenna lead for the bedroom radio was hanging down in the wall behind the radio head (see photo).
The RCA Radio is located in the entertainment center, its FM antenna is a loop type and is lying in the floor behind the radio and sound box. Elevating the loop antenna does improve the reception quality of this unit.
What I would like to know, how can I adapt some kind of antenna to the bedroom unit? It currently has terrible reception:
Name:	goshen frog rally 113.JPG
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 08-27-2013, 09:29 PM   #2
Is there a TV close to the bedroom radio? If so, you should just connect the antenna to your OTA antenna (and do that in the living room as well). You need to use one of these taps at each location. Use the "tap'd" output to go to the radios.
antenna, radio
