Old 04-19-2016, 03:47 AM   #1
woodyw333's Avatar
? for those who added awning lights
I bought a set of Superlite LED lights with the 44 button remote. My question is for those of you that have installed them (or any aftermarket lights) to the side of the camper under the awning. Where did you wire them into or do you just plug in and unplug every time you set up? Im wanting to hard wire into the camper so I don't have to climb up every time and plug in the wire to get power.
I have seen posts where people have wired into the scare light or amber light but they both are too far away from where the end would be and I don't want a wire just hanging around. Any help is greatly appreciated, pics would be awesome as well! Thanks!
woodyw333 is offline   Reply With Quote
Old 04-19-2016, 03:59 AM   #2
crunchman12001's Avatar
Hi,
We have a huge thread here from 2013 when the LED's first came out. Every possible installtion was used.
If you have a power awning, that install turns out the cleanest.
Here is the link.
My solution to awning lights
This is how I did mine. Pics from my album section.
http://www.forestriverforums.com/for...lbums1210.html
2015 F-250 FX4
Old 04-19-2016, 04:13 AM   #3
woodyw333's Avatar
Awesome!! Thank you! Great job, looks great!
Old 04-19-2016, 04:17 AM   #4
Thank you.
I did not have a pic of 12V power in the album. I just ran new wires from the 12V side of the panel with a new fuse to the switches for steps and awning.
Once you decide to do the install, we'll walk you through it.
2015 F-250 FX4
Old 04-19-2016, 04:24 AM   #5
woodyw333's Avatar
Originally Posted by crunchman12001 View Post
Thank you.
That sounds great! Hopefully it will be in the next few days, now that its warmed up a bit I have a few thousand things on my to-do list lol
Old 04-19-2016, 11:27 AM   #6
Dahagen
I attached them (with new 3M stickey stuff) to the side of the rv just below the awning. Then I wired them into the porch light. I can turn them on/off from inside.
dahagen is offline   Reply With Quote
Old 04-19-2016, 11:37 AM   #7
Left Coast
The hot set-up is to use a rf controller instead of the if.....can do it all from inside or out, never leav'n your chair!.....Power awning? run the wire down the upright that the awning motor uses and draw power from any 12 volt light....they make an extension 4 wire cord and there's quite a bit of accessories available.......I used alum track to mount mine and don't have to deal with any tape ....
Old 04-19-2016, 02:35 PM   #8
PapaE's Avatar
Our 5er came with LED strip lights across the underside of the awning base. Seemed like a great idea, until we used them in the summer. They are white and draw bugs. Are colors less prone to draw bugs?
Me & the DW
2016 Coachmen Brookstone 334RE Fifth Wheel
2015 Chevy 3500HD Diesel DRW Crew Cab 4X4 LTZ
PapaE is offline   Reply With Quote
Old 04-19-2016, 02:38 PM   #9
Left Coast
Yep...
Old 04-19-2016, 05:24 PM   #10
Question
Dahagen - what was the 3m sticky stuff.. I am looking to do the same and don't want them falling off while going down highway and byways.
Loma
bmaggin1 is offline   Reply With Quote
awning, light
