Old 05-05-2015, 06:35 PM   #1
Fresh water tank mod
I'm wanting to do a mod on my fresh water tank so I don't have to crawl underneath to open the drain. Has anyone out there done something like this before? I have an idea of how I want to do it but I'm open to any suggestions,thanks.
cruiser1701 is offline   Reply With Quote
Old 05-05-2015, 06:48 PM   #2
I did it on our popup years ago. I used PVC, galvanized pipe strap, and a ball valve on the end. Took about 1/2 an hour and saved my back for years. Just remember to give the pipe extending from the water tank enough of a pitch so it will empty.
Old 05-05-2015, 07:04 PM   #3
Yeah we did the same thing on our old popup,do you have any pics of what you did? I'd appreciate seeing them for some ideas being this is our first TT.
Old 05-06-2015, 06:44 AM   #4
That's a great idea I'll be doing that mod this summer. Thank you
kinma13 is offline   Reply With Quote
Old 05-06-2015, 08:28 AM   #5
I don't have any pics of mine but I did a search and found some pics of what others did.
And here's a link to a couple more pics:
Fresh water tank drainage - he-ruide
Old 05-06-2015, 10:13 AM   #6
GLCM Warrior
Lefty59's Avatar
One thing to consider when doing your mod is how much cold weather camping you do. The extended drain tube will become a freeze (and break) point in the fresh water system so you might want to insulate the line if need be.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 05-06-2015, 12:18 PM   #7
Great post. I was wondering how I could change mine ? Thanks for the Idea's !
The Outdoor Duffle Bag is offline   Reply With Quote
Old 05-06-2015, 12:37 PM   #8
The Factory has ours tucked in a Safe recessed area,you must think about exsposed (pipes/hoses/valves) when going (Down the Road) if Seasonal disregard! Youroo!!
youroo is online now   Reply With Quote
Old 05-06-2015, 02:13 PM   #9
Can't you just turn outside water off, turn on water pump, open some valves in kitchen a empty it that way.....just saying. ��
craigi is offline   Reply With Quote
Old 05-06-2015, 08:12 PM   #10
There you go again craigi. Always going for the EASY solution. Good Boy!!!
saltyman is offline   Reply With Quote
fresh water, tank, water, water tank, modifications
