When I sanitized my 50-gallon potable water storage tank this year, water started dripping from the trailer. When I removed the belly cover, I saw that my tank had sagged between the two 1-1/2” angle iron supports that ran parallel with the tank the entire width of the trailer. This sagging caused the angle iron to cut into the tank at two corners but did nothing to the sagging area of the tank. I used a Permatex plastic tank repair kit to patch the holes and a couple of layers of EternaBond roof sealant tape to cushion the tank from the angle iron. I don’t have any confidence this will last but it has held up well so far this year.
It looks like a couple of wide straps slung under the tank would provide adequate additional support for the tank that is susceptible to sagging. The two gray tanks and black-water holding tank, 50 gallons each, are built to rest on top of an angle-iron support and show no sign of sagging or deforming. I plan to add the straps to the potable water tank when I have time.
My potable water tank has several fittings and sensors penetrating it that were not spin welded. Instead, there is a copious amount of sealant at each penetration making them watertight.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
