02-08-2013, 08:29 PM
#21
Originally Posted by 10x
How did you attach & wire the inside one?
Mine is similar to the one shown here. It comes with a red wire that powers it. I found a "hot" wire on the back of the fridge that is accessable thru a removeable panel on the back of my FW.
You simply attach the provided wire to the hot one in the RV with a clip that is also provided with the fan.
The fan clips to the fins on the back of the fridge and when it is attached, it runs. When the fan is removed from the fins, it stops running.
Some have wired the fan thru the fridge door and some have wired it thru a separate switch.
There are many posts here regarding these fans also how to install them,
#22
no I stuck stove bolts through fan mounting case then soldered alligater clips on the ends allowing me to clip it to the fins .
would you like some closer pics ?
02-08-2013, 08:30 PM
#23
I will go take a few pics .
brb
02-08-2013, 08:46 PM
#24
02-08-2013, 08:58 PM
#25
[QUOTE=f1100turbo;303757] Attachment 24113
Attachment 24114[/QUOTE
Thats neat. does it make a big difference in keeping things cool & recover faster when you open door?
02-08-2013, 09:07 PM
#26
It definitely made a difference!
My dw even commented how much better it was doing.
And she's pretty hard to impress!
02-08-2013, 09:08 PM
#27
Question, does the fridge run colder with the exhaust fans or does it make it work easier?
Yes to both questions. Fans on the inside keep the frig at an even temp.
02-08-2013, 09:11 PM
#28
Originally Posted by f1100turbo
...And she's pretty hard to impress!
Won't say what I'm thinking.
02-08-2013, 09:13 PM
#29
WHAT? you bite your lip ..... say it isn't so!
02-08-2013, 09:21 PM
#30
All I can say is there must not have been very many boys in her hometown from which to chose.
02-08-2013, 09:28 PM
#31
Lol!
My g pa used to say if you can't baffle um with bull-s@$ t dazzle um with delight!
Happy happy happy
02-08-2013, 09:50 PM
#32
02-08-2013, 11:13 PM
#33
Originally Posted by bob213
Thanks for the link. Heck for 15 bucks it worth it.
02-09-2013, 02:53 AM
#34
What does everyone think of this one? It splices in somewhere behind the Fridge with the power wire going through the drip pan. I kind of like the not having wires dangling from the top of my fridge idea. Looks like a cleaner install to me, plus has two clips instead of one so less likely to get knocked off by my boys. http://www.ebay.com/itm/200831657441...84.m1423.l2649
2013 Columbus 320RS "The Wonder Wagon"
2009 F-250 4WD (Tuned) "Black Beauty"
02-09-2013, 08:01 AM
#35
Incheon, S. Korea
Are you looking to make your fridge more efficient?
Here's a drawing of the fan/baffle mod that I've seen and am going to do in spring. I hope it helps.
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
02-09-2013, 08:45 AM
#36
Oklahoma Proud
What about those solar powered vent covers with a fan that I've seen in our local dealers catalogue- kind if like a cw catalogue.
Anybody ever used these? Do they help?
02-09-2013, 08:54 AM
#37
They have a small percentage of air flow needed. Draw in milli amp , not 1-2 amps per OEM. They've come up here before. Cold make things worse if installed in natural draft duct exit by restriction.
02-09-2013, 01:31 PM
#38
Originally Posted by captbenjy
What does everyone think of this one? It splices in somewhere behind the Fridge with the power wire going through the drip pan. I kind of like the not having wires dangling from the top of my fridge idea. Looks like a cleaner install to me, plus has two clips instead of one so less likely to get knocked off by my boys. Dometic Norcold Refrigerator Fan for RV Boat 12V | eBay
That is the one I described in my post #21. The two clips hold it securely on the fin panel and it is easy to install - just find an accessable "hot" wire that is always "hot" when the fridge is on.
Don't expect a large fan if you order it - this one comes in a padded envelope and is very light - but as I said before, everything you need is included except a voltmeter for finding that "hot" wire.
02-09-2013, 01:45 PM
#39
What are they like 30mm fans?
02-09-2013, 01:51 PM
#40
I don't really know how big 30mm fans are.
