Old 11-13-2012, 07:47 PM   #1
Stank Bait's Avatar
Fridge Fan- Where Do I??
Here is a picture of my fridge. Where do I put the fan? I know where the 12v is to hook it up but can not find a pic that looks like this one. Thanks
Stank Bait is offline   Reply With Quote
Old 11-13-2012, 08:44 PM   #2
VinceU's Avatar
Factory mounts fans just below the condenser coil about one foot below the roof vent. If in slide there is a second access outside. If not can pull out fridge for access. Some have mounted in the horizontal baffle just inside the outside access. Check the forum search window for "dometic refridge fans". There's ideas and pics. You"re fridge model wii help.
Old 11-13-2012, 10:07 PM   #3
Stank Bait's Avatar
Model # is DM2652
I looked for a pic of a fridge that was outside (uninstalled) so I could see what was there. No luck. I understand where a fan would be placed at the top, through the upper vent but did not know if the bottom fan would go in the middle. Guess it may just have to go where it will fit. I found pics of fans but none looked like the one I have. maybe I am just over thinking it.
Old 11-13-2012, 10:31 PM   #4
TURBS's Avatar
Here's where I put mine.
Turbs
Old 11-14-2012, 06:51 AM   #5
Stank Bait's Avatar
Thanks. That helps. Figure you had a sore neck after installation. Did you put a switch on it too?
Old 11-14-2012, 07:20 AM   #6
Here is where I mounted mine.
Name:	Dual fans 1.jpg
ID:	21569   Click image for larger version
Name:	Dual fans2.jpg
ID:	21570   Click image for larger version
Name:	Looking up the refrigerator compartment.  White surface is back of trailer.jpg
Old 11-14-2012, 07:41 AM   #7
TURBS's Avatar
My fans come on when the fridge is turned on. Then later I added a switch to shut them off if I want separate from fridge.
Turbs
Old 11-14-2012, 08:21 PM   #8
Stank Bait's Avatar
Appreciate the pics. I think I can get it done. Just not to hot about putting them in from the top where they are more difficult to access. Thanks
Old 11-14-2012, 08:44 PM   #9
TURBS's Avatar
Thats why I put mine in the bottom.
Turbs
Old 11-14-2012, 08:54 PM   #10
Better to have the forced air blowing across everything, especially down at the bottom and then being funneled across the fins above. You can see where I located the switch for my fans.
Old 02-08-2013, 06:27 PM   #11
10x
I was wondering what is the purpose of adding the fans?
10x is offline   Reply With Quote
Old 02-08-2013, 06:30 PM   #12
TURBS's Avatar
To keep stale excessive heat build up flowing out the vent pipe .
Old 02-08-2013, 07:08 PM   #13
10x
Do you exhaust the heat out of the outside vent? Where do you purchase them and where do you mount it? Are they AC or DC operated?
Old 02-08-2013, 07:12 PM   #14
TURBS's Avatar
Got mine from best buy.
12v Computer fans .
previous posts show locations .
Old 02-08-2013, 07:14 PM   #15
TURBS's Avatar
Also have one inside to circulate the air.
Old 02-08-2013, 07:19 PM   #16
Have 2 on the outside and 2 on the inside. Never turn them off even tho' I have switches on both sets. Also have remote temp sensors in freezer and the refrigerator.
Old 02-08-2013, 08:17 PM   #17
10x
Attachment 24103
How did you attach & wire the inside one?
Old 02-08-2013, 08:22 PM   #18
TURBS's Avatar
I used the hot side of the interior light switch .
so that the fan runs even with door closed .
Old 02-08-2013, 08:22 PM   #19
10x
Question, does the fridge run colder with the exhaust fans or does it make it work easier?
Old 02-08-2013, 08:24 PM   #20
10x
Looks like you used tie straps to fasten it to the fins?
fan
