Old 12-23-2014, 09:37 PM   #21
Retired
Have a question concerning our furnace. We were camping and it got down to 40 so turned furnace on and it ran fine with hot air coming from furnace vents, but the air conditioner in the ceiling was also running with air going in (cold air return maybe) but also cool to warm air coming out. Is that normal.
tennlady is offline   Reply With Quote
Old 12-23-2014, 09:40 PM   #22
Kaadk's Avatar
Common occurrence with the digital thermostat. Switch the setting to Fan, switch the fan to Auto, then turn the furnace back on. Shouldn't have an issue with the AC anymore.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 12-24-2014, 12:36 AM   #23
I found that if you run the fan on low it helps to circulate the warm air.
rsv4pilot is offline   Reply With Quote
Old 12-24-2014, 01:43 AM   #24
sail2liv's Avatar
Wow, since not privy to conversation you had with your dealer, the whole story there is not known....but in our 26 ft flagstaff the three vents work great so far 3 yrs, 10k miles. Folks say the biggest problem is when boon docking is it drains battery. If hooked to 110 there should be no problem with battery drain. Not sure if a bad battery would affect air flow......good luck with getting the problem corrected...FR has been great in handling any issue we have ever had in our unit. I will always own one of their products just for that reason......they have always been excellent for us no matter where we were in our travels.
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 12-24-2014, 01:37 PM   #25
Coolharts's Avatar
I was using my RV as a Christmas package wrapping room with the heat on and the A/C was lowing air out. I have to give this a try to see if it fixes the problem.
Coolharts is offline   Reply With Quote
Old 01-21-2015, 12:32 PM   #26
Smile Rock wood 8289 furnace
We've given up on the furnace because it uses to much log.
The logs we use are free.
Andyrockwood is offline   Reply With Quote
Old 01-21-2015, 01:15 PM   #27
heavynlori's Avatar
Is that REALLY a woodburning stove with a chimney through the roof of your RV ??
heavynlori is offline   Reply With Quote
Old 01-21-2015, 02:13 PM   #28
Yes and it's lovely and warm even when it's -5○c outside.
The post should have read, it uses to much LPG.
Old 01-22-2015, 07:54 PM   #29
I was curious so I looked it up, sure enough it is possible. Here is one manufacturer: https://www.kimberlyepawoodstoves.com/
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 02-01-2015, 07:53 PM   #30
My unit was not blowing heat. Heat was only coming out under sink and drawers. The heater end was not installed.
bthreadgill is offline   Reply With Quote
furnace, trailer
