Old 04-07-2017, 05:43 PM   #1
Furrion Camera Help
I have a 2018 Salem Cruise Lite pre wired for backup camera. The wire coming from the camper has a male end. The camera coming from Furrion has a male end. Am I missing something! Click image for larger version
ID:	134096Click image for larger version
Age1456 is offline   Reply With Quote
Old 04-07-2017, 07:13 PM   #2
I ordered a female to female coupler. I guess if that doesn't work, I'll start splicing stuff together.
Old 04-07-2017, 07:16 PM   #3
Georgia Rally Coordinator
aceinspp's Avatar
Do you know what camera it is wired for? You may have the wrong one. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 04-07-2017, 07:21 PM   #4
Look very closley at the wholde assembly. I installed mine two weeks ago. The kit I ordered had extra parts because your camper already has the housing. I had to pop off the screws on the back and dissasemble then reassemble in the housing on the camper leaving me with extra unnecessary parts.
I believe what your pic shows will not fit into the housing on the camper. hard to explain online typing.
Kimber45 is offline   Reply With Quote
Old 04-07-2017, 07:37 PM   #5
It looks like it is wired for Way Interglo bal camera....this camera is more expensive and not a lot of information about it. I'm going to see if my coupler works and if not, I'm going to try to hard wire it. The brackets are identical.
Old 04-07-2017, 07:57 PM   #6
aceinspp's Avatar
Most are wired for a Furrion camera. Should have been some info in your instruction package that came with tt. Mine did. Later RJD
Days camped 2019 62
Old 04-07-2017, 08:11 PM   #7
It looks like the trailer has the wiring for the FOS48 observation camera.
The camera you have may be the older FRC12 backup camera.
Either way both will work with the proper adapter or by hardwiring.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
Old 04-07-2017, 08:51 PM   #8
I have the FOS48TAPK-BL
Old 04-07-2017, 09:50 PM   #9
So much for that theory.
Did the camera come with the mating pigtail. If it did you could splice that in to the exsisting wire after removing the connector.
Old 04-07-2017, 09:52 PM   #10
Yes, I can and will do if the coupler I ordered doesn't work.
Old 04-07-2017, 09:56 PM   #11
Always a joy when two products are the current versions and are supposed to work together, and they don't!
The prewire looks like a typical 5mm OD, 2.1mm ID 12 volt power plug while the camera connector is a 3.5 mm 3 circuit audio plug, odd choice by the manufacturer for a power plug.
Old 04-07-2017, 10:18 PM   #12
gectisme's Avatar
That picture kind of looks like that phono/audio plug on the camera will pull out, did you try that?
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 04-07-2017, 11:15 PM   #13
I just did. It does not come out.
Old 04-07-2017, 11:17 PM   #14
The camera plug is a 2.5mm, the pre-wire might be bigger but hope not because the coupler won't fit. Sounds like I will be splicing.
Old 04-07-2017, 11:19 PM   #15
I have looked through my stuff and only saw an ad for Way Interglobal cameras. I will look closer at my stuff tomorrow.
Old 04-08-2017, 10:08 PM   #16
SailorSam20500's Avatar
If you bought the Furrion kit, you should have gotten the correct power wire with it. If it were me, I would take it to your selling dealer and have them replace it as a warranty issue. It really looks like you got the wrong wiring on the power supply to the camera.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 04-12-2017, 07:26 PM   #17
grege's Avatar
The housing on your camper is definitely not for that camera. It should look like this. I don't see a place for the antenna in your picture.
https://www.kz-rv.com/products/sport...-Up-Camera.jpg
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
grege is offline   Reply With Quote
Old 05-16-2017, 08:42 PM   #18
Update.......found out today the pre-wire on the camper was for a specific camera sold at the dealership and was not compatible to Furrion. I had to uninstall the pre-wire and install what Furrion provided.
