Originally Posted by cherokeewolf
I know that my trailer is pre-wired for a Furrion rear camera. My tow vehicle has a full screen audio head unit already equipped with rear camera inputs. Has anyone found a way to link the trailer camera to a non-Furrion display monitor?
Your trailer is wired for a "camera" but the only thing Furrion is the mounting system. The "pre-wire" consists of 12v positive and ground wires tapped into the running light system. It has a connector that mates to the Furrion. Most folks just cut the connector off and splice the wires into whatever camera system they have.
Your vehicle display is probably a hard wired unit only. It's not compatible with any wireless camera unless you install an additional converter. As far as installing a complete hard wired camera system, good luck with that (unless you can get to the trailer before the exterior and interior panels are installed at the factory).
