Old 06-19-2016, 02:17 PM   #1
Furrion Camera only on while in Reverse?
I just put in my (presumably plug and play) FRC12TAPK-BL Observation camera for backup and high speed on my 2017 Surveyor and it will on only come on when I am in reverse. I assume it is factory wired into the back up lights but want it to be on all the time (at least when the running lights are on)
I was going to try to power in into the top center marker light but before I started poking around, wanted to see if anyone else already fixed my problem.
Any input would be appreciated
Thanks!
Cpratt1010 is offline   Reply With Quote
Old 06-19-2016, 02:28 PM   #2
Forbes's Avatar
Thanks!
Remove unit from mount and remove mount, you will find the power wire to the unit pushed back in hole, disconnect it from the backup wire and tape the backup wire off. Now remove one of your running lights (upper) and connect the camera to it. Now when running lights are on the camera is also.
Roger & Mary Forbes
WB4FSN
Little Lady (Dog)
2014 F350 / 2015 CC 36 CKTS
Days Camping 2014-96, 2015-130, 2016-126, 2017-42 and counting
Forbes is offline   Reply With Quote
Old 06-19-2016, 02:57 PM   #3
Hooked mine (after market camera) up to running light power. Drilled a small hole in bottom of lens for wire to exit. Scotchlok connectors worked nicely, no cutting wires.
Brewhedd is offline   Reply With Quote
Old 06-19-2016, 04:12 PM   #4
I bought the FOS48TA-BL RV, now waiting for the RV mtg kit. I'm going to place it about the center light in my coachman. Then I'm picking up 12V off the bath fan, then when traveling all I have to do is turn on the switch!!
Krlpj05 is offline   Reply With Quote
Old 06-19-2016, 04:26 PM   #5
Thanks Forbes, That's what I figured.. Next question then.. Any ideas what brand-type of silicone forest river uses?? I would like to match the DARK silicone (I see they use two different colors)
Old 06-19-2016, 04:36 PM   #6
I would use one that dries clear that way your headaches with trying to match the colors will be illuminated!
Old 06-20-2016, 06:02 AM   #7
Michael4017's Avatar
My factory one works with the running lights on. FYI, there are 2 types of this camera-backup and observation. The backup constantly cuts out while driving(good for slow speeds and the obvious backing up.
'16 Cherokee 274DBH
'16 F150 XLT Crew 3.5eco
Mike
2016 Cherokee Limited 274DBH
2016 Ford F-150
Michael4017 is offline   Reply With Quote
Old 06-20-2016, 12:30 PM   #8
keeprr's Avatar
You need the "48" model for observation while going down the road. The"12" model only works as a backup camera. I put the "48" model on my 43' 5er and it works fairly well while traveling for observation.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 06-20-2016, 12:31 PM   #9
keeprr's Avatar
Meant 32' 5er. Fat fingers are a b****.
Old 06-20-2016, 01:51 PM   #10
Utah Traveler's Avatar
FRC12TAPK-BL is a backup camera only model, (RC is for reverse camera)it is not an observation camera!
If you want a camera that does backup and observation as well while traveling down the road you will need model FOS48TA-BL (OS is for observation system.)
even if you wire yours to the running lights, it will cut on and off driving you crazy. The processor on the FOS48TA is faster anf will not cut out while traveling at highway speeds.
2016 Rockwood 2109S
2002 Silverado 1500 5.3 V8
Utah Traveler is offline   Reply With Quote
