Old 03-06-2016, 08:02 PM   #11
World Wide Wanderer
wahoonc's Avatar
Originally Posted by B and B View Post
I wired mine to a 12 v constant lead inside the cupboards at the back, just on the other side of the wall. The new version works great! I have the monitor just below my mirror. It is the same general area as the GPS and regular backup so a normal viewing spot.
From what I gather leaving the camera on a constant 12v feed will lead to a shortened life span. There are quite a few brands that have an early failure due to this. On my motorhome it is wired to the ignition, so it does get turned off.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 03-07-2016, 10:11 AM   #12
BDavis's Avatar
I have it wired to my running lights. I do run it on while towing to keep an eye on the back of the rig.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 03-07-2016, 07:36 PM   #13
X2
Gmar60 is offline   Reply With Quote
Old 03-07-2016, 07:47 PM   #14
Originally Posted by Gmar60 View Post
I had no idea the 7-pin plug had a reverse light in the mix (I have never seen a TT with back up lights)
My 1988 Coleman popup had backup lights. But I haven't really seen too many others, unless the owner added them.
2011 Traverse LT, 3.6L, FWD
Old 04-28-2016, 09:58 AM   #15
Do you have a recommendation on which Furrion system to get? Since our camper came pre-wired, does that mean I get a "wired" or "wireless" system? Probably a stupid question but my husband asked me to order one & I can't reach him to ask!
2016 Rockwood 2504S
Doxies in the Rockies is offline   Reply With Quote
Old 04-28-2016, 10:13 AM   #16
leefl's Avatar
The pre-wiring is likely just for power, so you'll need the wireless system in order to be able to have the monitor in the tow vehicle without having to run extra cables from the camper to the vehicle.
I'd recommend getting the "Observation" camera, since it helps when driving, for checking clearance, rather than just when backing into a site.
Wireless High-Speed Observation System. (For high-speed observation and backup use) - FURRION
It's about $100 more than the back-up only camera.
I got mine from an EBay seller, for about $100 less than buying direct.
I bought from General RV Center's EBay store and had no issues: -
Furrion Wireless Observation System Backup Monitor Camera Long Range FOS48TA BL | eBay
There are a few sellers selling for $50 less, but of course I have no idea if the other sellers are any good.
Make sure to get the FOS48TA if you want the observation/rear-view ability, and also if you need longer range (the other model loses signal on anything much longer than a small popup)
I wouldn't be without mine now, and have it on all the time while towing the 5th wheel (makes lane changes much easier, since I know 100% if I'm clear of that vehicle in the other lane)
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 04-28-2016, 10:26 AM   #17
Thank you! That's exactly what I needed to know! Having the camera for backing up will be nice but we definitely want to be able to use it for making lane changes safer & easier.
2016 Rockwood 2504S
Old 05-02-2016, 05:09 PM   #18
Update - we ordered a Furrion FOS58TA from Amazon & it arrived on Saturday. It took less than 15 minutes, in the snow, to get it installed and paired with the monitor in the truck. Now if the weather would just stay cleared up enough for the areas we want to go to melt & dry out!!!
2016 Rockwood 2504S
Old 05-02-2016, 05:10 PM   #19
Oops, we got a FOS48TA! It looks like it going to work great!
2016 Rockwood 2504S
Old 05-02-2016, 06:40 PM   #20
leefl's Avatar
Good to hear. Enjoy
