Old 12-12-2015, 10:42 AM   #21
I go RV'ing not Camping
jgourlie's Avatar
Originally Posted by youroo View Post
The total of 3/4 ply and the bigger mat is the issue,they need Larger PSI struts! Youroo!!
I for sure need bigger struts, but for right now I just live with it. I just store my satellite dish in there anyways so I don't need to open it often.
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 12-12-2015, 10:45 AM   #22
jgourlie's Avatar
Originally Posted by rmac04401 View Post
If you placed the other plywood on top of what was there why don't you just take out the bottom layer of plywood and screw the hinges in the one you added. Less weight.
If I took out the plywood underneath the head of the bed would be higher. I essentially had to go head to toe with the plywood to keep it even underneath the mattress. Not sure that makes sense or not, with my poor use of the english language?
Old 12-12-2015, 08:34 PM   #23
rmac04401's Avatar
Originally Posted by Bowhnter View Post
Our Vibe under bed storage did not come with any lift supports for the box lid.
After searching, all I can find are for truck bed lids which do not attach with screws.
Has anyone added any lift support and if so what did you use and where did you get them?
Preferrably they would hold the lid up unassisted when open.
Camping world has them. I am sure any rv dealer would. Just put rv bed lifts in search on amazon and they will come up. They also have the brackets.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 12-12-2015, 09:31 PM   #24
On the Heartland forum someone recommended Future Sales RV. I haven't used them yet but they seem to have a good selection and reasonable prices.
spudston is offline   Reply With Quote
Old 12-13-2015, 04:42 PM   #25
Swift2
Swift 2's Avatar
Don't know what I be done wrong but I had to remove the two 125 lb struts that came with the C and install 2-50 lb. struts. The 125 lb were just to heavy. They ripped up the hinges on the plywood and the plywood would bend when trying to put the bed closed back down. I tryed changing the mounting points several times but just couldn't seem to out smart those darn struts.
Swift 2 is offline   Reply With Quote
Old 12-15-2015, 06:41 AM   #26
For those of you who need higher pressure ones, pull off one of your existing ones and you will find the part number. This part number will correspond with the pressure it takes to compress the strut. I went from 100# to 120# on each side to hold my bed up. The great part about using the same brand you have is you can get the higher rated struts and install on your existing brackets. Just use a flat head screwdriver to pop off the retaining ring on each end and they come right off. Then pop the new ones on. It's a 1 minute job that only costs about $12 a side.
Karl4Cat is offline   Reply With Quote
Old 12-15-2015, 08:25 AM   #27
TURBS's Avatar
Napa has a huge selection of gas struts including mounting brackets.
bed, gas, storage
