Old 07-22-2016, 01:48 PM   #1
Gas grille set up
I have a Vibe 272bhs and have recently purchased a portable weber gas grille to take along camping. I was wondering if I can use the quick disconnect propane connection at the rear of the trailer to feed the grille.
twentz is offline   Reply With Quote
Old 07-22-2016, 01:51 PM   #2
jeff
jeff64's Avatar
Of course you can. There are lots of threads on this one. Use search feature
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-28-2016, 08:42 AM   #3
Yes you can and I have done the same for my Weber Q200. I can use a bulk tank (normal 20#), 1# disposable, or the RV. I just need to hook up the proper line to go with the supply that I'm using at the time.
A search will give you all that you need but I got most of my "stuff" from "caloreequipment dot com". Very helpful people to work with.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 08-02-2016, 04:22 PM   #4
Fred H.'s Avatar
Yes you can BUT you must remove the gas regulator on the Weber.
The gas line going to the rear of your rig is down stream of the main gas regulator. You cannot use the regulator on your grill and reduce it further.
The fix is very simple. Just un-screw the regulator on the weber grill, you may need to purchase a brass connector, like I did, that goes from the grill to the new lp hose you purchase with a quick disconnect on one end.
Your all set. It will now work great for you. The plus side is you will save $$$ on not having to buy those small 1 lb. cans of lp gas to hook up to the grill.
Fred n Wilma
2014 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 08-02-2016, 04:42 PM   #5
SeaDog's Avatar
Looks like you got the information you were asking for I will add I was skeptical about using the outside grill that came with my rig, however I now just love it what a great addition.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-03-2016, 11:04 AM   #6
Another option is to get the adapter hose to go from a bulk tank to the grill. It works well and is easier and cheaper than the conversion.
John M
Old 08-05-2016, 02:02 PM   #7
Thank you all for your assistance
gas
