Old 05-09-2016, 03:13 PM   #1
TURBS's Avatar
Generator 50 amp mod
Recently I took my generator to the guy that I've dubbed " generator guru" to have him remove the worthless four prong 120 "15 amps" /240 "30 amps" volt floating neutral outlet and replace it with a 50 amp Rv plug to get a true 50 amps.
To my surprise he called me today and said I can pick up
The catch is I have 50 amps total available not the normal 100 amps "50 per leg" you'd find at a power pedestal.
So technically I can run both a/c units "if needed " and have approximately 15 to 20 amps left over.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-09-2016, 03:20 PM   #2
Toby's Avatar
Hmmmm I think I might need to bring mine over and see what can be done. I was just thinking about buying a new one.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 05-09-2016, 03:47 PM   #3
TURBS's Avatar
What do you have Toby?
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-09-2016, 03:53 PM   #4
W5CI's Avatar
I don think RV parks have 100 amp pedistals, they are 50 amp, 25 amp per leg. IMHO
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 05-09-2016, 03:55 PM   #5
TURBS's Avatar
Each leg "2" is an individual leg of 50 amps at a cg pedestal not 2 legs of 25 amps.
Old 05-09-2016, 03:58 PM   #6
AquaMan's Avatar
I concur
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-09-2016, 07:05 PM   #7
Toby's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
I believe it's a champion but not sure what model. Here's a picture of the panel. Click image for larger version
Name:	ImageUploadedByForest River Forums1462838598.111410.jpg
ID:	107401 the one I was looking at had a rv plug in it out of the box. I'm not even convinced this one would run my ac anyway. It runs everything else and was a lifesaver when we had that major hail storm a few years ago and the power was out for three days.
2018 Ford F250
Old 05-09-2016, 07:09 PM   #8
TURBS's Avatar
Originally Posted by Toby View Post
I believe it's a champion but not sure what model. Here's a picture of the panel. Attachment 107401 the one I was looking at had a rv plug in it out of the box. I'm not even convinced this one would run my ac anyway. It runs everything else and was a lifesaver when we had that major hail storm a few years ago and the power was out for three days.
No it won't run your a/c or maybe just barely.
The 120/240 plug shown is misleading, it says 30amp, however it's only 30 amp on the 240 side and 15 amp on the 120 side.
That generator with that plug could be 8000 watts but that outlet would remain 15amps.
I brought him the generator and the 50 amp receptacle and he charged me $80.00 to rewire it to 50 amp.
He did my other generator as well a few years back but it is wired for 30 amp.
And actually your household duplex plugs on there are rated for 20 amp and would be better.
Old 05-09-2016, 07:21 PM   #9
Toby's Avatar
I can believe that. I'll just get a new one that will do the job sometime later this summer. I rarely use it but we might be dry camping in August and I know for sure I'll want the A/C going. I'll sell this one at a garage sale or something at that time. This one I picked up at an auction and it's been a great little handy resource to have out here. I just need something a little bigger that could potentially run the well pump and the A/C (although not necessarily at the same time).
2018 Ford F250
Old 05-10-2016, 09:04 AM   #10
TURBS's Avatar
If noise is not a problem you have many options!
2008 2500hd Duramax
2015 Columbus 320RS
50 amp, generator, modifications
