Old 10-14-2012, 06:08 PM   #1
Skier0277's Avatar
Generator (Capable for 50a)
I'm in the market for a portable generator for our 5th Wheel. Does anyone have any recommendations which to use? Was looking for a quiet model that was capable of running up to 50a to power both AC units.
Skier0277 is offline   Reply With Quote
Old 10-14-2012, 06:18 PM   #2
Two Honda 3000's in parallel should do. Only other option would be the built in onan.
chiro is offline   Reply With Quote
Old 10-14-2012, 06:21 PM   #3
Skier0277's Avatar
I saw those could be parralleled,would you just have to make a cord with a 30a connector from each generator to a 50a connection to the camper?
Old 10-14-2012, 06:26 PM   #4
Too old to be too smart
SpringerPop's Avatar
Two Honda 3000-watt gensets would not have to be "sync'd" to operate a fifth-wheel with a 50-amp plug, as each leg is completely isolated from the other, but you have to remember that you still will only have 25-amps per leg, not 50.
3000/120=25
You'd likely be able to run both A/Cs, but adding in additional draws like microwave ovens, electric water heaters, and toasters might be a bit much.
Remember, at 120-volts, two Honda 3000s are 6000 watts, and a fifty-amp RV service is (50 + 50) x 120 = 12,000 watts.
Not exactly the same thing.
To answer the preceding question, yes, a custom "Y-Pigtail" would be the best way of connecting it all.
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 10-14-2012, 06:38 PM   #5
Skier0277's Avatar
How about the brand/model, is the Honda a good choice for the money?
Old 10-14-2012, 06:38 PM   #6
TURBS's Avatar
We have a 9.6k with a 20 hp twin cyl briggs engine at the shop and it's still only 30amp
Not very portable either. Or quiet .
Turbs
Old 10-14-2012, 06:39 PM   #7
Skier0277's Avatar
Thanks for your input/advice, very helpful info
Old 10-18-2012, 01:02 PM   #8
daydreaming about camping
jeeplj8's Avatar
I dont know that I have ever seen a portable gen actually rated for 50 amp service. Many have a 30 amp plug, but dont actually make a true 30 amp.
I think you have a choice between portable or 50 amp, but not both.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 10-18-2012, 01:25 PM   #9
wmtire's Avatar
Having a quiet generator for 50 amps is going to be a challenge, really depending on your definition of what quiet is.
I have seen some Generac portable generators at Home Depot that have a 50 amp receptacle as well as just looking at some Champion brand name ones a month back when we were threatened by a hurricane.
Here is one of the Champion ones at Camping World, that even though it has a 50 amp receptacle, you are still limited to 7500 running watts.
http://www.campingworld.com/shopping...enerator/56918
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-18-2012, 02:14 PM   #10
Lynkage's Avatar
Onan has a 12.5K but at 770lbs not really portable.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
