Old 08-05-2014, 10:33 AM   #91
Who Dares, Wins
doc73's Avatar
I hope you do not mean your living areas... if so the carbon monoxide will make sure you do not wake up one morning. All gasoline engines produce this no matter how clean they burn...
If it is in a gene compartment made for this ignore the above!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 08-05-2014, 10:39 AM   #92
MotocrossCamper's Avatar
Sorry, I should have explained that better. We bought a 5th wheel Toyhauler to see if we like it better then the Mororhome and the original genny was bad. We put the Polaris in the front compartment meant for it. My only concern was that the exhaust was just pointing out the front and not routed underneath as the original one was. I put I digital CO2 detector in the compartment with the genny and all is good. Inside the compartment it only gets to 10 ppm.
MotocrossCamper is offline   Reply With Quote
Old 08-05-2014, 04:18 PM   #93
Who Dares, Wins
doc73's Avatar
Ok. That is what I was hoping, but yet people still die every year around here when they run the generator in their basements when their power is out so you never know!
2015 ChevyHD D-Max
Old 08-17-2014, 09:21 PM   #94
Taranwanderer's Avatar
So does anyone have a real world report on the Champion 3100 inverter? True sine wave, 3100w max, 2800 cont, 58db. Anyone have any negative experience with it? I can't see the downside to this genny...?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-17-2014, 10:15 PM   #95
That's next on my list
Kuba is offline   Reply With Quote
Old 08-18-2014, 06:24 AM   #96
Ordered!
Old 08-18-2014, 11:39 AM   #97
I have had one for a couple of months. I have used it a few times but I have only ran the AC for a short period of time to test it. So far I have no complaints with the unit. Has always started on the first pull and runs without issue. Relatively quite. The RV outlet on the front is great to be able to plug in the camper without an adapter. I could lift it into the back of my 1500 pickup but upgraded to a 2500. Now I can still get it up there but it is much easier with someone helping.
grubbster is offline   Reply With Quote
Old 08-18-2014, 02:04 PM   #98
ironj's Avatar
What size a/c and what were ambient temps??....
At nearly 4000ft and at 90+ ambient the power loss from max stated is significant!!.. 4% per 1000ft over sea and another 1-2% for every 10 degrees over like 80..
Champ has been very fort coming and timley in replies regarding derating their gennys...honda however (which I also own) has been vague in replies and slow to reply if/when they do....
Both are great units and perform flawlessly....and I can better choose which unit to run based on my needs and environment.
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 08-18-2014, 02:11 PM   #99
ironj's Avatar
Originally Posted by mikegp1 View Post
I saw one at Lowes. I believe it was a champion. 4kw with a 30amp Rv outlet. Doing simple math would power ac. It says 68db which is not more then a Honda. And only 300. I am thinking about buying one. I need it for twice a year at the race track since my generator is now permanently mounted in the race trailer.
The champ is way louder than a honda or even a similar branded 2000 inverter....
At a race track I would run the 4000 tho as I doubt noise will be of any concern.....they are fine units, for situations like that....especially if u want to run an a/c ..a smaller one MAY do it, but not on eco mode and not without some work!..even the smaller ones are pretty loud when u wack em with a significant load and they throttle way up..
Old 08-19-2014, 09:46 PM   #100
It's here...
Didn't get to take it out and fill it, start it, and run it yet. It's killing me... Report to be forthcoming...
