Originally Posted by Skip12
Some pics or model information would be helpful. If door shock hod it open, and are stopping it from opening as much as you'd like, you could consider removing those and latch the door all the way open like most other access doors on a camper, assuming nothing else gets in the way like a window or awing arm.
Hooe that helps.
Definitely need more info.
On mine I have to stretch some to reach the edge to pull mine down and I'm 5-11" so not exactly "vertically challenged". Even my 6'-4" Son has no issues with the O/S kitchen door on my TT.
Could possibly be that gas struts are not proper ones and aren't lifting high enough. I'd be interested in whether or not the rod is fully pushed into the cylinder when door is down. If not it could be merely a wrong install of the lower bracket and when door is open the piston is bottoming out before door is fully open.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
