Old 06-03-2016, 05:39 AM   #1
Golf cart battery location
I am installing 4 6 volt golf cart batteries in my grey wolf 26dbh. There is not enough room for them on the tongue. Any suggestions on where to locate them?
First trailer is offline   Reply With Quote
Old 06-03-2016, 08:30 AM   #2
In one of my previous campers, I ended up using AGM batteries (ventless) and putting them under the bed.
If you pull the coroplast cover off the bottom of the camper, you may find real estate that a welder can use to fabricate battery racks for you. Make sure you vent the area if not using AGM batteries.
Skyliner is offline   Reply With Quote
Old 06-04-2016, 03:27 PM   #3
Consider just two....would this box fit on your tongue?
Century Plastics: White Heavy Duty Battery Box - (part#: GCE-G)
In my case my tongue weight was way to high. I put my two golf car batteries inside the camper behind the axle. I sealed up the box and put in a two inch vent that is plumbed into my black tank vent.
All is well and my batteries don't smell like poop
Wankrl7 is offline   Reply With Quote
battery, cat, location
