Old 07-25-2012, 07:43 PM   #1
Goofy LED ribbon lights
My led lights have (5) sections of 3 leds that are out of sequence with the rest of the lights. When all the rest are white, red or anything but these 15 are blue. When they cycle to blue, they catch up until it goes to yellow and they go to blue. Weird. The 5 sections are not together, but at random places.
Old 07-25-2012, 07:46 PM   #2
Md Jeff's Avatar
Can you set yours to not cycle and stay one color? I just purchased a set of Ebay and they haven't arrived yet, figure I will be leaving it on one color and hope for the best.
Md Jeff is offline   Reply With Quote
Old 07-25-2012, 07:59 PM   #3
Yes, they will stay one color. It seems to have something to do with the red column of colors. Those 15 just don't like red. DW doesn't either, so no big problem.
Old 07-25-2012, 08:56 PM   #4
Timex's Avatar
Was it made in China? Maybe those 15 lights were made in Taiwan. They don't really like the Chinese but have to get along!
R.O.C.
Timex is offline   Reply With Quote
Old 07-25-2012, 09:01 PM   #5
R.O.C.
You know they were made in China and you are probably right that the 15 were made in Taiwan.
Old 07-25-2012, 11:13 PM   #6
This message board makes me laugh. That is all. Carry on.
forensicdeac is offline   Reply With Quote
Old 07-25-2012, 11:17 PM   #7
Every time I see a I laugh...lol
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 07-25-2012, 11:41 PM   #8
TURBS's Avatar
Someday it's a real laugh fest around here!
Old 07-26-2012, 06:18 AM   #9
Herk7769's Avatar
I have one LED set of one string that sometimes does not light red.
All other colors on that LED set work fine.
By pressing on the middle square LED, it will stay "fixed" for many days.
Then after a drive, the next time I use it it will be "broken" again.
It is a cold solder joint in that LED. It will be a PITA to fix (CAREFULLY cut through the rubber covering so as not to sever anything that could knock out the entire string down stream; Find the cold solder joint and re-solder it without melting or destroying the rest of the circuit; RTV the repair so it won't corrode or block the lights I just fixed.
So, since it is only one (it IS in the middle so I can't trim it out), I plan on living with it till I can't anymore. Then I plan to use an "off cut" to patch it in with some small hookup wire.
I am sure if I notify the sender he would make "good" with a new string, I just have not done so.
HAM CALLSIGN - KC3FFW
Old 07-26-2012, 10:00 AM   #10
CRZ
CRZ's Avatar
I had the same problem but with 4 LEDs. Pushing them did help but only for a few minutes. I started messing with the pin connecter. I cleaned it up with a pocket knife by just slightly scraping the pins(gently) and reaming the holes. Now it lights up almost always and if it doesn't I just press the pin connector together more. My first thought was a led connection problem but now I think it's a power issue at the pin connector. Something to try out first.
CRZ is offline   Reply With Quote
