Old 02-13-2012, 04:36 PM   #1
Warrior's Avatar
Handrail installation
DW has always had a problem getting up and down the steps to the bedroom. The single handrail at the foot of the step is just not sufficient.
I found a similar handrail on-line. I want to mount it vertically to the opposite wall. That is where the problem comes in. The wall is an exterior wall.
I'm at a loss on how I should mount it. It has to support the weight of a person. The only method I can come up with is to through bolt it. Go completely through the wall with long bolts, fender washers, nuts and caulked.It won't look very good though
Any ideas?
Wayne & June Bowers Camp Mutts Bo & Baby
2011 F250 Lariat 4X4 SCSB 6.7 Power Stroke
50 Gallon Titan Fuel Tank
2011 Flagstaff 8528RLWS 5th Wheel
Reese Sidewinder Hitch 2002 Road Star Warrior
SouthWest Florida FROG
Warrior is offline   Reply With Quote
Old 02-13-2012, 07:53 PM   #2
Warrior's Avatar
Is there a type of glue suitable for this application?
Old 02-13-2012, 08:06 PM   #3
TURBS's Avatar
boy I am at a loss about what to do for ya !
The problem is whether there is a supporting joist behind the wall. and where there located .
I would consult a local rv dealer whom handles flagstaff . or better yet contact flagstaff your self to see if they can help you with the behind the wall construction and what you are attempting to do .
at least they may be able to tell you what your running up against and cant help you better make a plan to get your dw up those stairs !
They probably have dimensions of the joist spacing to better serve you .
hope this helps !
Old 02-13-2012, 11:09 PM   #4
I would not bolt through the wall, until you know what is there. Not sure on your trailer, never worked on one, but here are a few tips. If it has paneling inside, look for a vertical row of staples, maybe putty filled holes, that would indicate a stud. You can sometimes push on the inside wall, and find the studs. Use a "stud finder" . If the outside is aluminum, it is not thick enough to hold anything. If is is smooth side, still won't offer much support, and will probably crack around the screw hole eventually.
I can't think of many options, maybe others can. Can you mount a rail to the floor, like for a front porch rail?
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-14-2012, 05:48 AM   #5
PapaSmurf's Avatar
In looking for a new unit this year, we saw several that had wrought iron railings mounted to the floor. Should be able to buy some at the local home center. If you mounted it close to the wall, it should not be any more obtrusive than a hand rail, maybe even less. My DW has mobility issues as well. When I saw the wrought iron railing, I filed that idea away for future needs. Maybe it will help you as well? Here in our neck of the woods we have an 1800's village, with a blacksmith group. That is where I intend to get mine made when the time comes.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
PapaSmurf is offline   Reply With Quote
Old 02-14-2012, 07:27 AM   #6
sherdep's Avatar
I am with PapaSmurf's idea - Maybe instead of wrought Iron it could be constructed out of Aluminum to save on weight - Might be a little more expensive but worth a shot
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-14-2012, 07:34 PM   #7
wfmdfm's Avatar
I would think some type of plate on the outside rather than the fender washers. Possibly some diamon plate. There are places that can cut the plate into a decorative shape. The other side of the stairs could be a choice if it is a inside wall and you find the studs. Good luck and post some pics.
Wally
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 02-14-2012, 07:58 PM   #8
Dave_Monica's Avatar
Depending on the exterior, aluminum siding or fiberglass they'll be 2x2" wood or aluminum framing. I'm not sure if the manufacturers build the exterior walls 16" on center or 24". The secret would be finding the wood or aluminum 'studs' for an attachment point for a railing. Perhaps a stud finder will work...I haven't tried one.
The other option would be to attach the handrail on an interior wall. The wallboard cover is very thin and you're easily able to detect where the wall stud is. The studs on the interior are most likely 2x2" wood.
Dave
Old 02-16-2012, 12:45 PM   #9
Warrior's Avatar
Thank you for all the responses.
I ended up attaching the handrail to the interior wall, as this was the only wall I could locate a stud. It's the framing for the bath door.
DW is happy with the location, so mission accomplished.
Old 02-16-2012, 03:16 PM   #10
Iggy's Avatar
Like to see a picture on what you installed.
We have a similiar issue and I'm not sure where and how I will install.
