05-29-2014, 12:46 PM
Always Learning
Hang folding table in basement storage
I'd like to hang a 6' folding table (so 3' x 3' x 3"-ish) from the basement storage hatch's ceiling. I swear I've seen a solution here before- just can't find it.
05-30-2014, 12:23 PM
I'm sure OC will be along shortly with something that will work
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
05-30-2014, 12:30 PM
Always Learning
And if he does, it'll be implemented with aluminum and since my father in law will be helping me with the next set of camper mods, I'll be able to do whatever OC says to!
05-30-2014, 01:05 PM
How about some pictures of the table (length, width, thickness folded) and the basement ceiling with dimensions. Do you want it stored laying flat on a rack in the ceiling or hanging by a handle from a hook in the ceiling or against a wall, etc.
05-30-2014, 01:07 PM
Always Learning
I can go measure the table, can't measure the camper until Sunday at the earliest.
Flat against the ceiling. It has exposed "rafters" (i.e. the aluminum framing for the floor above).
05-30-2014, 01:11 PM
I used four eye screws and two bungie straps, table just slides in nicely.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
05-30-2014, 01:15 PM
Originally Posted by ependydad
I can go measure the table, can't measure the camper until Sunday at the earliest. Flat against the ceiling. It has exposed "rafters" (i.e. the aluminum framing for the floor above).
Measure with pics of table. If the ceiling is completely clear, might it be possible to store it the 3' x 3' x 6' length with the legs folded? Put one end up in a rack from one side and go around to the other side and lift the other end up into a rack by one person or a person on both sides of the basement?
05-30-2014, 09:13 PM
Always Learning
I'll need to be able to do it by myself- my wife generally takes care of the inside while I do the outside stuff. Love my daughter dearly- but not yet ready to require her. :-)
I was thinking a rear lip that I put one end of the table into then lift the front/closest side to me and "close" the holder.
I was thinking of angle aluminum for the rear and then rope or bungee or something for the front. I'm not sure yet if I'd have to secure it from shifting in any direction.
Measuring one side:
Measuring the other:
Measuring thickness:
05-30-2014, 09:29 PM
We have one just like it. How about an alum rack on one end and a hook to put the handles in on the other end?
Another option, 2 hooks, one on each end and leave the table unfolded?
I'll play with it on cad and see what happens.
05-31-2014, 05:10 PM
Sketch of a pc of pvc pipe in 1/8 x 1" alum straps bolted thru a rafter to hold one end of the table and on another rafter, a 1/8 x 1" alum strap hook to loop the handle over.
06-02-2014, 07:34 AM
Always Learning
OldCoot - thanks for the drawing. How many of your projects start as drawings vs. you standing in your garage looking at your parts?
I really like the idea of hanging the back end by the handle. I think that'll make it to hit and should hold it pretty securely without worrying about side to side movement.
The only wildcard is the front end. I have to look and see how much room I have to slide the table in. My storage hatch doesn't extend the whole way up to the ceiling, so I'll either have to set it back far enough (which could make it unwieldy for getting it up there) or think up a different front side.
I do greatly thank you for your time thinking this up and throwing the idea out there.
06-03-2014, 01:04 AM
I was thinking about doing the same but only on the floor by making a sleeve for our table to fit in. As of now we have to put the table in first and then load the rest of the stuff on top which makes for a lot more work when you only want to pull out a few things. Our table is 6' but doesn't fold but I have the same concern as you with the door to ceiling height difference.
06-05-2014, 12:07 PM
Always Learning
CBergstrom, here's my plan for the floor:
I had the same issue with my zero gravity chairs. Everything went on top of them to the point I begrudgingly would get then out.
Here are really crappy pics of the ceiling:
Looking from the inside out, it's about 7" difference from the hatch door to the ceiling:
I have a drain pipe about 24" off the wall of the basement (closing off the space under the stairs) about 40" back from the hatch opening/camper side:
The hatch opening is about 24" tall by 46" wide (using my 2' level as a measuring stick).
And, here's the mess I'm trying to tame:
06-05-2014, 01:24 PM
That looks exactly like Glenn Jurcyzk's basement that we put the sliding drawer in. Plumbing in the ceiling, etc. His rolling shelf ended up 35-1/2" wide and 52" long. Works great. He has the problem of a large door on the road side and a small door on the other because of his furnace. If you have a large door on both sides, it would work even better as the shelf could roll outside both doors for access from either side.
06-05-2014, 01:27 PM
Always Learning
Very cool. I've started on my over-built wood shelfs. We'll see how I like it. The worst case, I rip it out, have some expensive firewood and then come visit you!
I'm a little concerned about the ceiling dimensions with hanging the table. I guess I could go below the plumbing with the idea of hanging the rear end of the table by the handle.
How would you secure the aluminum straps to the ceiling? Just pop-rivets (if so, what size)?
06-05-2014, 01:45 PM
I used hex head self drilling #10 x 3/4 screws, to hold up my garage door track, but 3/16" pop rivets would work or just a bolt clear thru and get both ends of the strap at once like the line shows going clear thru. # 10 or #12 x 2" should be plenty long.
06-05-2014, 02:19 PM
Always Learning
Ahh, ok- I see the "like the line shows going clear thru" now. These line drawings are a new thing for me.
06-05-2014, 03:16 PM
Old Enough to Know Better
ependydad
What about using 1x solid pine instead of 2x. It would save some weight and give you a little more fudge room. Its not like your supporting a lot of weight.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
06-05-2014, 03:27 PM
Always Learning
Originally Posted by gasman6674
ependydad
I hear you, I was just worried that 1x wasn't going to hold up to the "not gentleness" that my family is known for. In hindsight, it sure seems like it would have been plenty.
I've already bought the wood and started cutting it up. Tonight I cut the square for the plywood top and then I'll start screwing it together.
06-05-2014, 03:34 PM
Look forward to seeing finished product
