Old 07-15-2016, 05:07 PM   #11
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
Hard start Capacitors
Think of a capacitor as like a toilet for an electrical charge. Yeah, I know but work with me here. It gradually fills up with electricity when not being used, then when the circuit is closed, it"dumps" the charge in milliseconds for a "jolt" to get the appliance going. It has no effect what so ever on the line voltage before or after discharge. If you have low voltage before, you will most likely have the same voltage after the start.
I installed HSCs on both my A/Cs on my TT and all three A/Cs on my home.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 07-15-2016, 05:11 PM   #12
Canadian Member
itat's Avatar
My thought is that it might store and supply (boost) enough current on startup to avoid dropping the supply voltage below 104 but I know I'll still need more than 104 volts once the compressor is running, otherwise the EMS will still shut down the power supply.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 07-15-2016, 05:13 PM   #13
KenHwy61's Avatar
Great analogy!
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is offline   Reply With Quote
Old 07-15-2016, 05:38 PM   #14
Canadian Member
itat's Avatar
In my post, EMS means Electrical Management System, as in my 30 amp Progressive Industries EMS.
Old 07-15-2016, 10:48 PM   #15
WolfWhistle's Avatar
The compressor motor is of the inductive type ... when the motor shuts off, there is refridgerant pressure held in the head, which is difficult to over come at start up. The Start Assist capacitor does just that, giving the motor more torque (with the available voltage), for a very brief moment in time and then it "drops out" after its job is done... an induction motor can turn either direction but can't start on its own and needs either an external force ... or better yet, a start capacitor to "direct it" in which way to turn ... it does this by shifting the natural trailing voltage phase forward in time. These capacitors are charged and discharged 60 times a second.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
WolfWhistle is online now   Reply With Quote
Old 07-15-2016, 11:31 PM   #16
KenHwy61's Avatar
to add to this: the A/C system operates with high head pressure (200 psi or more) and lower suction pressure about 65. For this reason it is important for the compressor to remain off for several minutes between cycles. this off time will allow the pressure to equalize and allow the compressor to start much easier.
2012 Ram 2500HD CTD
