Old 06-07-2012, 03:46 PM   #11
bob213's Avatar
If you already have a start capacitor it is a simple swap..2 wires. If not, you piggyback onto your run capacitor. The SPP6E has a instant restart feature where the SPP6 does not. I'm trying to find out which is the correct one to use?
bob213 is offline   Reply With Quote
Old 06-07-2012, 03:47 PM   #12
bob213's Avatar
f1100turbo...please tell me more about the delay feature.
Old 06-07-2012, 03:48 PM   #13
VinceU's Avatar
Originally Posted by herk7769 View Post
So anyone have a wiring diagram/pictures of what wires to cut?
Inquiring minds and all that...
Here ya go I hope!
Old 06-07-2012, 03:53 PM   #14
VinceU's Avatar
Start Relay and Cap.
e is for 5 horsepower, spp6 is for 3 HP per mfg. brochure. Don't think that a/c is 5 HP.
Old 06-07-2012, 03:59 PM   #15
bob213's Avatar
According to the link you posted above the 6E is for 1/2 to 3hp. The differenece seems to be the electronics of it.
Old 06-07-2012, 04:03 PM   #16
bob213's Avatar
Try this link:
RV Air Conditioner Hard Start Capacitor | ModMyRV
But I still get conflicting answers as to the 6 or 6E
Old 06-07-2012, 05:25 PM   #17
bob213's Avatar
Reading down the list of comments on the above link from Modmyrv, I found this:
If you are adding a hardstart to your RV A/C unit, use the SPP6 [no E]. The SPP6E is not designed for 120VAC applications, The “E” series is also an instant restart unit, this does not allow the generator sufficient time to rampup to full power. The SPP6 has the preferred PTC relay and allows a longer ramp up time. The SPP6 is rated for 120VAC usage.
Remember for every thousand feet above sea level you generator drops 3% of output. On hotter days the A/C drops in efficiency as well. Check with your A/C manufacturer on the correct generator size for your unit. As far as I know there is not a manufacturer that will reccomend a 2000 watt generator to run a 13,500 BTU A/C unit.
If you have any questions about the SPP6 or any other Supco part, please contact us at 1-800-333-9125 ext. 261 our Tech Support will be glad to assist you.
Thanks,
Jim Berry
Director Product Management
Sealed Unit Parts Co., Inc.
Guess I'll go with the SPP6.
Old 06-07-2012, 10:12 PM   #18
VinceU's Avatar
Thanks,
Jim Berry
Agreed, most diff is the "e" is new and costs near 3x as much.
Old 06-08-2012, 07:46 AM   #19
I read somewhere that a rep from Supco said not to use the SPP6E with a generator. I'm not sure but all I can tell you is I installed the SPP6 on my air conditioner and it works fine on both shore power and generator power.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 07-25-2012, 07:11 AM   #20
ILUVRVing's Avatar
Sorry - just tailing / searching the forum(s) - I have a 2006 Cherokee 305B 5er that just started having AC start up issues. After a trip from VA last week that was in the mid to upper 90's. The AC would run all day, then @ night when it finally reached the stat set temp the AC would shut off, BUT then on start up would blow the 20amp AC breaker. I'm looking to do this mod - add (replace~I think) the start up cap to a Supco Mfg. - SPP6 - Hard Start Capacitor (which is on its way in the mail).
Now just to be clear on the Hard Start Capacitor mod ( I haven't looked at my AC yet) - am I REPLACING or adding it? I have a Duo Therm AC unit. I hope to do these mods this week end - I would appreciate it if I could use your info and you to help out.
Marge: Homer, is this how you pictured married life?
Homer: Yeah, pretty much, except we drove around in a van solving mysteries.
My album; past and present projects:http://www.flickr.com/photos/9617164...7600656468619/
ILUVRVing is offline   Reply With Quote
led pad
