Old 02-06-2016, 01:36 PM   #1
Too Tall's Avatar
Hard start capacitor and time delay relay to AC
Added hard start capacitor and time delay relay for better AC starting performance while on generator (or shore power). This is a popular upgrade for those of us with small generators.
https://youtu.be/NVkCjPh7Nd8
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 02-06-2016, 10:33 PM   #2
I go RV'ing not Camping
jgourlie's Avatar
Thank you for the video....watched the whole thing...very informative!
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 02-06-2016, 11:22 PM   #3
DougP47's Avatar
Nicely done I have a domestic unit and I'm going to try the fan delay when it comes in. I already have the hard start cap installed. I found the timer on Jet.com for less than $6.00.
Ram 1500
Big Horn
Hemi 5.7 2011
Salem 30KQBSS 2012
DougP47 is offline   Reply With Quote
Old 02-06-2016, 11:32 PM   #4
Too Tall's Avatar
Thanks for the comments.
USMC 68 -70
Old 02-07-2016, 04:38 AM   #5
Witch Doctor's Avatar
That's a good video. You can see the difference those two little things can do and help. Even if your not on a ginny which is why most people do it, It is still a good idea to do even if your plugged in all the time. The Total cost is like 20.00 bucks or so and easy to do, and your compressor and power source will thank you. I would think it would almost be a must with a 30 amp unit.....Good Job Too Tall.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 02-07-2016, 01:51 PM   #6
Canadian Member
itat's Avatar
Glen, I'm curious as to why you think this is a good idea if you are always on shore power?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 02-07-2016, 01:53 PM   #7
Who Dares, Wins
doc73's Avatar
I would think the less high draw off the 30amp system will save the breaker from tripping under the right circumstances..
I have the hard start already but I am now thinking about this delay. I am still also debating the relay Turbs posted some time ago to make my AC run off the heater thermostat.... GOD I HATE THIS SITE!!!!!!
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 02-07-2016, 02:23 PM   #8
jgourlie's Avatar
Now one thing that I kind of ignored was the delay because too tall has the coleman thermostat and I have the dometic digital thermostat which I automatically assumed meant it wouldn't work for me.
Does anyone see any reason why a delay would not work for my dometic... now having said that, when I fire up the a/c the fan runs first for probably 10 seconds and then the compressor kicks in....maybe dometic already has a delay built in.
Any help is appreciated,
Old 02-07-2016, 03:49 PM   #9
Too Tall's Avatar
Turbs has a Dometic with the time delay. It will work with either as it's 12 volts that energizes the fan relay. IMO, The relay doesn't know whether it's dometic, coleman or whatever. If your thermostat does start the fan first, you might want to get the 3 to 60 sec as opposed to the 0 to 10 second delay as you may need a little longer delay to overcome the built in delay. This is what I"m thinking, others can confirm.
USMC 68 -70
Old 02-08-2016, 04:15 AM   #10
Doc 73, is correct that is why I still think it's a good idea. It doesn't take much to get to 30 amps if like your water heater decides to kick on at the same time. Also a hard start is used to kick your compressor into run faster from start-up amps. It's just a capacitor that stores power to assist in the start mode, then drops out. We use to install them on any unit that would cause what is called nuisance tripping. When I was an HVAC repair man. Many, Many years ago.....Cheap mod and insurance...
