Old 10-04-2011, 11:32 PM   #1
HONDAMAN174's Avatar
Hard start capacitors
Looking for info on a hard start capacitor for a microwave and Mach 3 A/C unit. Only have 2000 watt gen to power trailer so looking for a solution vs. Bigger gen which I can't carry/move.
Just glad to get away
Old 10-04-2011, 11:37 PM   #2
TURBS's Avatar
how many amp outlet does your gennie have ?
Old 10-05-2011, 08:00 AM   #3
Second sentence in original post, "Only have 2000 watt gen to power trailer"
Maybe we need to take time to read ALL of the original post before firing off a response.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 10-05-2011, 08:04 AM   #4
TURBS's Avatar
Maybe you should take your advice and read my post!
I CLEARY asked what his outlet AMP was. Not watts
I also clearly asked a question and did not fire off a response.
If he only has a 15 or 20 amp outlet a hard start capacitor will not solve any problems.
to. Run air and a micro at same time would require more than 20 amps
Old 10-05-2011, 08:39 AM   #5
Herk7769's Avatar
This "bickering" is not helping Hondaman174.
Hondaman174,
It might help to know what you are trying to accomplish. Is your Honda 2000 the EU200i or the EU200i Companion (or something else)?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 10-05-2011, 08:57 AM   #6
Okay...good to see others trying to help me.
To answer all questions, gen is a honeywell (generac) 2200. Rated continuous output is 2000 @ 17 amps. Not trying to power both at same time just trying to power up a/c to cool or micro for a short burst.
Old 10-05-2011, 09:02 AM   #7
TURBS's Avatar
Most a/c units need 16 amps to start 13 amps to run
Most micros. Need between 8 to 13 amps to run
Spp6e or spp6 hard start kit it what you need for air conditioner
made by supco
I don't believe there's anything for micro. But I could be wrong.
Old 10-05-2011, 09:07 AM   #8
BigDTx's Avatar
ok, lets all be nice here!
BigDTx is offline   Reply With Quote
Old 10-05-2011, 09:09 AM   #9
TURBS's Avatar
Also is that 17 amp continuous amps or surge amps?
if its surge amps you don't have enough gennie to properly run air in my opinion.
Old 10-05-2011, 10:18 AM   #10
jimh's Avatar
hard start capacitor will only work with motors. ur microwave wouldn't qualify. motors in microwaves are very small. the big user (magnetron) isn't reactive.
hard start capacitor would help ur air/c. may want to check the manufacture web site for kits. i've read some post here where they have been added and work.
ur generator should be large enough. u will have to consider the other items it is trying to run at the same time to know for sure. ie converter, frig, tv, hot water heater...
i believe f1100turbo has a good guide showing usage of the other items in ur trailer.
jimh is offline   Reply With Quote
Old 10-05-2011, 11:18 AM   #11
My apologies. I should have added that Watts = voltage times current. Therefore 2000 watts, as originally posted, divided by 120 volts equals 16.6 amps.
Now if we go with 2200 watts, amperage equals 18.3 amps.
Post #6 stated 17 amp continuous, or roughly 2000 watts. Take in account some looses for cords and such, and the converter running, altitude, etc., it will be tough to run the AC. Also if you have a 15,000 btu air conditioner, it will never start, even with hard start capacitor.
LadyWindrider
Old 10-05-2011, 11:47 AM   #12
TURBS's Avatar
chart
One other thing to keep in mind is many RV appliances require more amps to start the appliance than they do to run the appliance. A roof air conditioner can draw 16 amps to start, but may only use 13 amps once it is running.
120 Volt AC Amp RatingsAppliance or Electronic EquipmentEstimated AmpsAir Conditioner (X number of A/C)12-16 AmpsBlender5-6 AmpsCoffee Maker5-8 AmpsCompact Disc Player1 AmpComputer (Laptop)2-3 AmpsConverter1-8 AmpsCrock Pot1-2 AmpsCurling Iron<1 AmpDrill2-6 AmpsElectric Blanket0.5-1.5 AmpsElectric Fan1 AmpElectric Water Heater9-13 AmpsElectric Skillet6-12 AmpsHair Dryer5-12 AmpsIron5-10 AmpsLight (60 watt % 120V)<1 AmpMicrowave8-13 AmpsMicrowave (Convection Oven)13 AmpsRefrigerator in AC mode5-8 AmpsSpace Heater8-13 AmpsTelevision1.5-4 AmpsToaster7-10 AmpsVacuum (handheld)2-6 AmpsVCR1-2 AmpsWasher/Dryer14-16Amps 12 Volt DC Amp RatingsAppliance or AccessoryEstimated AmpsAisle Light1 AmpCO Detector1 AmpFluorescent Light1-2 AmpsFurnace10-12 AmpsLP Gas Leak Detector1 AmpOverhead lights (Per Bulb)1 AmpPorch Light1 AmpPower Roof Vent1.5 AmpsRadio/Stereo4 AmpsRange Hood (Fan & Light)2-3 AmpsRefrigerator (LP Gas Mode)1.5- 2 AmpsSecurity System1 AmpTelevision (12 volt)4-5 AmpsTV Antenna Booster<1 AmpTV Antenna Booster 12 Volt outletUp to 8 AmpsVariable Speed Ceiling / Vent Fan4 AmpsVCR Recorder / Player2 AmpsWater Pump4 Amp
Old 10-05-2011, 11:50 AM   #13
TURBS's Avatar
thanks for the watt = voltage times current .
I never remember the formula and had I could have figured it out my self .
Old 10-05-2011, 12:06 PM   #14
frankm's Avatar
turbo, I also can't remember the formula (to just about anything) without associating it to something easier to remember. So, anytime I need to calculate volts, amps or watts, I think of a WAVE. As in Watts = Amps * Volts. The E is for excellent!
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 10-05-2011, 12:42 PM   #15
bikendan's Avatar
i have never heard of a Honeywell starting a Coleman a/c, even with a hard-start kit, on any RV forum. maybe it would a Dometic.
it'll be interesting to see if the OP can get it to work.
Old 10-05-2011, 06:09 PM   #16
rbarrieau's Avatar
How much of the initial amp draw could be reduced if the Fan on the A/C is running prior to turning on the A/C unit?
Rich + Lori -2006 salem 27BHSS/2004 Avalanche
4:10 rearend - Roxy the puppy when allowed.
41 Days camped in 2011 and counting.
rbarrieau is offline   Reply With Quote
Old 10-05-2011, 06:10 PM   #17
TURBS's Avatar
not sure what you mean ?
Old 10-05-2011, 06:30 PM   #18
Alright...thanks everyone. The capacitor is pretty cheap so I'm going to give that a try. I'll repost how it works after I get it in.
Old 10-05-2011, 06:31 PM   #19
KyDan's Avatar
My honda eu2000 will start my roof AC on a nice cool day in Kentucky at
600 ft alt.
Out west at 6000 feet on a warm afternoon it won't.
I tried turning on the fan first so both motors wouldn't be trying to start
at the same instant but still no go.
I never tried a bigger capacitor.
Peace!
Dan & Rita D
Old 10-05-2011, 07:03 PM   #20
rbarrieau's Avatar
Hondaman sounds like the EU2000 companion is needed to run your roof top with no problems. never mind I thought you had a Honda 2000.
can you link your generator to another?
