Old 03-07-2016, 08:24 PM   #11
Turbs...thanks for the link to your a/c install. Lots of good info. I subcribed to the topic to keep it handy. I'll be un-winterizing soon, so I'll be able to get in there and take a good look and see if I can do a set-up similar to yours. I'm a little reluctant to do too much cutting on the rig since its still new and under warranty, but we were camping in Branson over Labor day weekend and it was about 95 degrees during the day. One a/c unit trying to cool a 35 ft trailer with 2 slides couldn't even begin to keep up, so I've got to do something.
2015 Rockwood 8315 BSS
2015 Silverado 2500HD 6.0
Ginger & Sammie (our 4 legged kids)
US Navy veteran
Movike is offline   Reply With Quote
Old 03-07-2016, 08:47 PM   #12
TURBS's Avatar
If you need any help pm me and we can talk.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-08-2016, 12:29 PM   #13
Originally Posted by TURBS View Post
I ran an additional 30 amp service to my camper.
Then ran a wire from that service through the walls and up through the ceiling to the a/c.
I had to use a video scope in the walls to run the wire.
I've got more and can maybe help you through the process if needed.
I then ran my normal 30 amp camper plug to a dog bone off the 50 amp service on the pole and ran the second a/c 30 amp cord to the 30 amp.
I'll see if I can find my thread.
2015 Columbus 320RS
2008 2500HD Duramax
Hey Turbs....I got a question for ya. I heard of several that have the pre-wired 50a 5er. When adding that second AC, they took the wires from the breaker for it and connected a cord to run off the 110v at the post. This way, if they were at a 30a site, they could adapt their 50a cord to the 30a post plug and also plug in the 2nd AC to the 110v outlet also on the post. 30AMP site running two AC's. Doable?
Gregg & Denise
2006 F-350 CC LB 6.0 Diesel 4x4 DRW
2014 Heritage Glen 366bh
2015 Camping---"162 Nights"
2016--Moved in camper 11/2015 while
getting ready to sell sticks-N-bricks
PIGMAN is online now   Reply With Quote
Old 03-08-2016, 12:36 PM   #14
TURBS's Avatar
Doable !
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-08-2016, 12:45 PM   #15
Phat Phrog Stunt Crew
elind's Avatar
You might check out this adapter to the same thing.
Camco 55025 PowerGrip Maximizer 45 AMP Adapter
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 03-08-2016, 01:16 PM   #16
Which method is better, a/c in bedroom controlled by wall thermostat or local control on bedroom a/c?
jcarrico is offline   Reply With Quote
Old 03-08-2016, 02:02 PM   #17
TURBS's Avatar
No real difference other the you have to run a wire for the wall mounted thermostat.
Normally the ceiling controls are non ducted and wall thermostats are ducted.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-08-2016, 06:12 PM   #18
Re: bedroom air
Hi all, here is my feedback re the bed room air.
I have s 29RE Silverback and it was pre wired for the bedroom air. Check your electrical panel for a second air conditioner breaker as well as wiring when you remove the inside of the bedroom vent. Our trailer has a 50amp service but we end up with only a 30amp park connection a lot still. We can't run both air on 30 amp circuit. We had our 13500 BTU put in completely local in the bedroom. Our inside air cover has it's own vent and controls. I made sure that the heavy foil that opens the feed to the rest of the trailer ceiling vents were kept CLOSED. So on a hot day the when the main air is having trouble keeping the trailer cool, in the evening we can shut off the main air and just run the bedroom air. Keeping the door almost closed the bedroom can be as cool as you need for sleeping. This has worked out well for the last 2 years.
klaatu is offline   Reply With Quote
Old 03-08-2016, 07:23 PM   #19
I would like to thank everyone who has replied with ideas and comments. I special shout out to "TURBS" who took the time to talk with me for about 30 minutes and answered every question I had. Great group of people on this forum.
Thanks again,
GM4X4
GM4X4 is offline   Reply With Quote
Old 03-08-2016, 07:26 PM   #20
TURBS's Avatar
Thanks again,
GM4X4
Your welcome!
If you need anything, let me know!
2015 Columbus 320RS
2008 2500HD Duramax
bed, led, roo, roof, vent
