Old 03-06-2016, 07:57 PM   #1
Has anyone installed a/c in the bedroom of a DLX 39FDEN using existing roof vent?
I have a 2015 Wildwood DLX 39FDEN that currently has a roof vent installed in the bedroom. The salesman told me that the vent was pre-wired for a optional 2nd A/C unit if I wanted to add later on. Has anyone ever performed the install?
GM4X4 is offline   Reply With Quote
Old 03-06-2016, 08:12 PM   #2
dieselguy's Avatar
I don't have your specific model, but I have installed a front A/C in the existing roof vent cutout. If you indeed have the unit prewired, it's a fairly easy straight forward swap. The two hardest parts are cleaning the sealant from where the vent sat and getting the A/C up on the roof. There are two options as well ducted ... or just blow air directly out the ceiling housing. There's also the ability on some models (if compatible) to run your second air off an existing dual zone thermostat instead of off the ceiling unit itself. It's mostly all in the instructions that come with the units.
dieselguy is offline   Reply With Quote
Old 03-06-2016, 08:28 PM   #3
Phat Phrog Stunt Crew
elind's Avatar
I had a second A/C installed on my Wildcat that was pre-wired. It took less than a hour to complete the install. Happy with the results.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 03-07-2016, 12:43 PM   #4
Are these rigs 50 amp or 30 amp? I'd like to add a second
a/c to the bedroom in my rig, but wasn't sure if I could since my camper is 30 amp. I haven't checked yet to see if there is existing wiring in the roof vent.
2015 Rockwood 8315 BSS
2015 Silverado 2500HD 6.0
Ginger & Sammie (our 4 legged kids)
US Navy veteran
Movike is offline   Reply With Quote
Old 03-07-2016, 12:45 PM   #5
TURBS's Avatar
I've done both added a second a/c to a 50 and 30 amp camper.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-07-2016, 12:50 PM   #6
TURBS's Avatar
I ran an additional 30 amp service to my camper.
Then ran a wire from that service through the walls and up through the ceiling to the a/c.
I had to use a video scope in the walls to run the wire.
I've got more and can maybe help you through the process if needed.
I then ran my normal 30 amp camper plug to a dog bone off the 50 amp service on the pole and ran the second a/c 30 amp cord to the 30 amp.
I'll see if I can find my thread.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-07-2016, 12:53 PM   #7
TURBS's Avatar
Here.
Adding a second a/c to a 30 amp camper. Adding a second a/c to a 30 amp camper.
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-07-2016, 03:54 PM   #8
Thanks for all of the replays. My DLX is a 50amp and I don't think I should have any power issues.
My concerns are:
1) Will the existing wires already installed for the 2nd ac unit be pre wired for my thermostat that already controls my main ac unit?
2) My main unit is a Dometic Breeze II and was thinking of using the same in the bedroom. There is a pluming vent coming through my roof about 4" away from the opening of the existing roof vent in the bedroom where I would install the new ac. Will that plumbing vent be in the way? You would think that Forest River would of made sure that it wouldn't be a problem, but you know what happens when you "assume".
3) My main unit can be switched the run the air in the duct work throughout the trailer or just come out the unit itself. Will the 2nd air unit do the same or should I just run the air out of the unit so not to have the units working against each other?
4) My roof is rubber based. What is the best way to remove the sealant around the existing bedroom roof vent?
Old 03-07-2016, 04:19 PM   #9
TURBS's Avatar
Has anyone installed a/c in the bedroom of a DLX 39FDEN using existing roof v...
My concerns are:
Pm sent
I'll answer all your questions via a phone call then type them in later after we've talked If you don't mind
2015 Columbus 320RS
2008 2500HD Duramax
Old 03-07-2016, 08:22 PM   #10
TURBS's Avatar
My concerns are:
1) pull inner vent cover off "4 screws" you should see wires.
2) tbd as per phone call.
3) non ducted is your best bet.
4) heat gun, patients and a putty knife.
2015 Columbus 320RS
2008 2500HD Duramax
bed, led, roo, roof, vent
