Old 09-24-2012, 08:34 PM   #11
Originally Posted by GlacierGus View Post
FreedomTracker, we have the same set up- a heated mattress and I just added a 2" memory foam pad. Going for a long weekend in nothern Mn on Oct 6th. We will probably get a chance to try the heated mattress. I'll let you know if the heat comes through.
I would guess you won't get much heat thru the 2" memory foam as we tried putting the heating pad under it and got nothing until we put the pad on top of the foam.
Good luck, maybe the heated mattress puts out more heat.
Old 09-24-2012, 08:40 PM   #12
GlacierGus's Avatar
Thanks dunnnc. I suspect you are correct.
2013 Rockwood Mini Lite 2109S
2006 Dodge Durango Hemi 5.7
Equal-i-zer WDH
GlacierGus is offline   Reply With Quote
Old 09-24-2012, 09:22 PM   #13
Rlawson's Avatar
We've been using a heated mattress pad on a 3" memory foam for about 3 years, no problem at all....
Rlawson is offline   Reply With Quote
Old 09-25-2012, 08:32 AM   #14
FreedomTracker's Avatar
Just to clarify... we have a heated "mattress" not a "mattress pad". The 2" memory form has no choice but to go on top.
Fortunately, living in FL we have minimal cold nights... just want to dtermine what to expect when we flip the switch..?
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 07-16-2014, 09:29 AM   #15
Wondering whether it's ok to put a 1" memory foam on top of heated mattress. Concerns are does heat come through foam and/or does the foam hurt the heated mattress?
Jaelford is offline   Reply With Quote
Old 07-16-2014, 10:08 AM   #16
We used to have a heated mattress with a 1" memory foam topper and it worked great, don't know about 2" though.
comfun1 is offline   Reply With Quote
Old 07-16-2014, 11:14 AM   #17
mark0224's Avatar
We have a heated mattress with 2 " MEMORY FOAM topper I wouldn't turn heated mattress on memory foam holds enough body heat and makes bead hot enough. Don't know what happens with the mattress if it shorts out would it melt the topper and cause you to get a bad burn?
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
