Old 07-10-2015, 01:51 PM   #1
heater vents
Ever get tired of dirt getting in heater floor vents when not in use? I did and came up with an idea of cutting out plastic covers out of the cheap plastic cutting board that you buy from Wally world, you know the ones that have 3 or 4 in a pack. Take the vent up and cut to fit outside cut hole and drill hole where screws go and then replace vent cover. No more dirt or dust getting into vent and then remove when cooler weather comes. May be old to some but I was proud when I figured it out
scott_silverside is offline   Reply With Quote
Old 07-10-2015, 02:09 PM   #2
ddphillips52's Avatar
I replaced all of mine with residential models that can be closed. That way they catch the dirt before it gets into the ducts. Check Lowes or Home Depot. They carry different sizes.
Dennis, Linda, and Scout the Dog
2015 Mesa Ridge 347 RES
Husky 16KW with Reese Sidewinder
2013 4WD RAM 3500 Cummins TD SBCC
ddphillips52 is offline   Reply With Quote
Old 07-10-2015, 10:24 PM   #3
WFD
Same here that way we can keep them closed in summer and in fall or spring if we need to throw on the heat, just open the vents.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 07-11-2015, 07:09 AM   #4
cpaulsen's Avatar
Same here!
cpaulsen is offline   Reply With Quote
Old 07-11-2015, 07:25 AM   #5
dieselguy's Avatar
We've replaced the stock plastic ones with louvered metal stick house versions as well. We even go as far as buying those magnetic covers for the vents during the summer ... makes cleaning easier.
dieselguy is offline   Reply With Quote
Old 07-15-2015, 08:35 PM   #6
We have a beagle and two Chihuahua mix dogs, plus we very the coast/beach often. Dog hair and sand easily get past closed louvers. So what works for us is to wrap the vent in a couple of layers of the Blue painters tape. You can tape just the underside of the vent and the tape will trap ALL dirt from falling into the vent. It is easily peeled off for winter use.
2011 8314 BSS Rockwood Signature Ultralite
2005 Dodge Ram 2500 Quad-cab SLT
Makoto is offline   Reply With Quote
heater, vent
