Old 07-29-2012, 07:51 AM   #1
Help digi thermo replacement
Pleaseexcuse me for any stupidity if I overlooked something. I spent the time to read all the post i could find on this and printed the instructions. I have a 2012 rockwood 8317rkss, It has a coleman mach analog. I bought the Walmart Hunter digi thermo, I installed the switch for high and low fan.
On the wiring schematic I printed it has red wire not used, yellow-cool, orange-low fan, blue-high fan, white-furance, and black as the ground.. When I removed the thermo from the wall the wired didnt match up in color, So i found the schematic for the thermo that was installed in the TT. instead of orange it was gray and instead of blue it was green..
I have tripled checked my wiring and can not get the ac or furnace to come on. Any ideas what could be wrong?
thanks in advance for any help
mgg123 is offline   Reply With Quote
Old 07-29-2012, 08:12 AM   #2
Blackrock's Avatar
Mod #100: Honeywell, Dometic and Suburban Digitial Thermostat Install | ModMyRV
See if this helps ya any. This is something I am planning on trying soon.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 07-29-2012, 09:18 AM   #3
ill give it atry
I'll read through this and see if it helps, I used a non programable hunter 4299B..
Old 07-29-2012, 09:36 AM   #4
no help
Blackrock, thanks for the info. I actually used mod #37 from that site. It was linked on this site..Not real sure whats going on.. I'll keep trying
