Old 06-13-2014, 01:21 PM   #11
Ford Idaho's Avatar
I would just cut a 2X4 to the same height as the tank and place it next to the rod.
Old 06-13-2014, 01:22 PM   #12
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Almost half of the 20# is transfered to the axles and not to the tongue.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-13-2014, 01:34 PM   #13
Kaadk's Avatar
Not true, unless the distance from tank to tongue is equal to the distance of tank to axles. While some of the weight will be on the axle, since the tank sits directly on the tongue, the majority of it will be on the tongue. Without pulling up the formulas, I'd guess only a pound or so of that weight actually sits on the axles.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 06-13-2014, 01:36 PM   #14
If 5.25#(15% of 35#) is going to overload your tongue, you need to maybe remove the spare tire, jack & tire tools from the tow vehicle as 99.999% of the time you don't need it.
Old 06-13-2014, 02:08 PM   #15
tlambert's Avatar
Help me with double propane tank holder
Originally Posted by MOD Guy View Post
How about removing the threaded rod, moving the tank to the center, and placing a threaded rod on each side. Get a small section of square alum tube from a home center, drill a hole on each end for the rod, and place the tube thru the tank collar to connect the rods and hold down the tank.
You could also use the old Coleman pop-up version:
http://http://www.ebay.com/itm/Coleman-Fleetwood-Pop-Up-Camper-20-Lbs-Propane-Tank-Hold-Down-Brackets-/141305629117?_trksid=p2054897.l5658
^^^^^ I like this idea.
Doesn't really matter why he wants to remove the tank. Just needs a way to help mount the remaining tank.
Tim
tlambert is offline   Reply With Quote
Old 06-13-2014, 02:44 PM   #16
Fulltime family RVer
My pop-up only ever had 1 propane tank with it. These worked well.
ependydad is online now   Reply With Quote
Old 06-14-2014, 12:14 AM   #17
Get a piece of chain link fence top rail pipe,cut it the same length as the height of the propane tank wear the cross bar fits and use it in place of the tank. You may have to add a third notch in the cross bar or widen one of notches to fit the pipe.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 08-13-2014, 12:06 PM   #18
Old Ram Guy
Avenger61's Avatar
I know this is an old thread but the first thing I thought of was cutting a 2" or maybe 3" piece of PVC pipe to the right height and notching the ends to catch the bracket. Once you tighten the bracket down on the PVC pipe and the other bottle I would think it would hold it fine and weigh very little.
Marty, Jenice and DD
Avenger61 is offline   Reply With Quote
propane, tank
