07-01-2018, 09:16 AM
Help - Modifications - Running Boards - Bad Knee
Hello fellow FRF folks - I've recently started to have knee problems and find it's not quite as easy to get on the running board and into the truck . Does anyone have and tips or modifications to help with this dilemma?
Debbie
2017 Flagstaff Super Lite - 832IKBS - Diamond Package
2006 GMC Sierra 2500HD
Been an RV owner since 2003
07-01-2018, 09:22 AM
Coach
Do you have space to install some grab bars?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
07-01-2018, 09:37 AM
In addition to grab bars, they make running boards that drop down with electric actuators, then lift back up when the door closes. They might be lower to the ground in the extended position than traditional running boards.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
07-01-2018, 09:43 AM
My friend and his wife have had the same problem. On their last two trucks, they took each to a welding shop, and had the factory running boards lowered and moved outward a little. Then they had just the step height they needed.
07-01-2018, 12:03 PM
Inside I have a great grab bar
Are you talking about something on the outside of the truck or the inside?
We have a GMC SIERRA 2500 and it DOES have a great grab bar across the dash that I LOVE and use all the time but it's getting that bad knee up the 12 or 14 inches to the running board.... I'll have to measure the height. I didn't want the DH to have to put down and pick up a stool for me... I can navigate shorter steps just fine... but when the steps gett higher then 6 inches it becomes more difficult.
07-01-2018, 01:15 PM
Post a picture of what you have now.
You may be able to install an additional step below it.
2017 Dynamax REV 24RB
2018 Ford F-150
07-01-2018, 01:48 PM
Hey jdstrubel, I have the same truck as you and have the automatic extending steps as mentioned above. Mine are Amp-Research Powerstep's. The steps do come lower and further out than any other steps that I know of (we got them for my wife when she was pregnant). When extended they are about 11 1/4 inches off the ground and they stick out a little over 5" from the rocker. Note that my tires are a couple sizes bigger than stock and I raised the front end of my truck a couple of inches to level it off so the running board height is slightly higher than it would be on a truck with stock tires and ride height. This is certainly not the only option for you, but it's a good one.
Quality AMP Research Powerstep & Truck Running Boards | AMP Research
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
07-01-2018, 04:52 PM
Saw an older couple a few years ago. She would use a small plastic foot stool with a piece of rope tied to it. After she stepped into the truck she would pickup the step stool with the rope and drop it behind the seat. When she would get out she just reversed everything. Good luck, John
07-01-2018, 04:55 PM
OH Dear... that is so funny because I thought about doing the VERY SAME THING... thanks for sharing that you had seen this couple do the EXACT thing I was thinking of....
07-01-2018, 05:00 PM
Pics of current running boards.... and distance from ground to step
Okay here are the PICS showing the running board and distance from the ground... Thanks "DELCO BOBBY" for suggesting I include these - Pictures ARE worth a 1000 words...
07-01-2018, 06:33 PM
Yep! Old age ain't for sissies, that's for sure! My DW can't get into my truck without a running board and some handles. If she needs a step, I will make sure she has one.
2015 Palomino SolAire 20RBS
2022 Silverado 2500HD LT Duramax 4WD
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days; 2019: 8 days; 2020: 0; 2021: 10 days.
07-01-2018, 07:17 PM
Mine on my F350 were 19" from the ground. I went the welding shop route and had the brackets extended 4". All the difference in the world, and no real appearance problem.
Sent from my SM-T813 using Forest River Forums mobile app
07-01-2018, 08:32 PM
Attachment 177975
Attachment 177976
That is a huge step up.
You have received a few good suggestions here.
In my are there is a store that sells and installs truck accessories and equipment. You may have one in your town. Go there to see what you like.
You might be able to use a truck bed step installed under your running board.
2018 Ford F-150
07-02-2018, 02:07 PM
I started making a list of local shops over the weekend - will try to start making some calls. Right now getting ready to head out for the holiday weekend... Woo Hoo... 6 days of Mental Health days and R & R .... Oh and hopefully some Md Crabs in there as well.... Thanks SO MUCH for your comments and Suggestions!
I'm feelin' the love from the RFR GANG!
Debbie
07-02-2018, 07:33 PM
Debbie
I saw a couple of RV service shops at the Timonium show that probably could help you.
There is also a place that I think is near the entrance to a Gettysburg RV Park that people give good reviews.
I have to apologize because I don’t remember the names and a search of my files didn’t help.
2018 Ford F-150
07-02-2018, 07:58 PM
Thanks for sharing the information you did... I will try to do some searches and see what comes up. We are actually going to Deer Run Camping Resort in Gettysburg PA - in about 2 weeks - wouldn't that be funny if it was near THAT particular Campground...
You sound like me... I save lots of information in files on my computer but sometimes finding it after I've saved it IS a REAL task... I know I saved it just not sure in WHAT folder...
DebbIE
07-03-2018, 02:53 PM
You should definitely look into these. We have them and they are great.
07-03-2018, 03:09 PM
I am thinking it is one of these ...
JR RV repair
SS RV repair
2018 Ford F-150
07-16-2018, 03:31 PM
Another quick option that might help is a “Stander Handybar” 3 in 1 vechicle support handle. It fits into your stationery door lock bracket. It’s about $25, or less. My DW uses it even on our car. You do have to insert it each time, but quick & easy. You can get from Amazon & many other places (Home Depot shows on there website but haven’t seen in the stores). The electric/retracting steps are a better more permanent solution.
2021 Forest River Vengeance Rouge Armored 371A13
2021 GMC Sierra/Denali 3500HD SRW
Anderson Ultimate 24k Hitch
07-16-2018, 05:16 PM
Stander Handybar - well would you look at that!
I have NEVER seen one of those in my life... How HANDY is that! Thanks SO MUCH for sharing this neat little gadget.... Debbie
