Help: trying to install washer/dryer prep in CC 30lrl
My Cedar Creek 30LRL did not come with Washer/Dryer prep from the factory. I am going to install myself, however, I am trying to find out where and how the factory ran the water supply lines and drain line. Anyone have a similar floorplan or know the answer. I believe the water lines are run under the dresser then into the closet hooked up in the storage compartment. This will be the easiest. I am struggling with the drain line. If I drop it straight out of the closet where the hookups are typically installed...it will come out on the section of the kingpin....which is very difficult to get to. If I attempted to run under the dresser, i am not sure where I would drop to hook up. Someone Help!! Please....
Jeff
