Old 05-14-2013, 07:59 PM   #1
RPAspey's Avatar
Here's how I found a stud..
I wanted to mount a TV some time ago in my TT and wasn't sure how to find studs and wires. Sooo, I borrowed an Infra Red camera from work and aimed it on the wall. I loaded the outlets in the area with some heaters or something. I looked around and there are the studs. The white vertical lines are the studs. The one on the left is at a wallboard joint, that one was obvious, but the other puzzled me. Here I discovered that I have a double wall, where the outside studs are not connected in anyway to the inside walls. I did confirm this with my bore-scope that I bought at a later time.
The round object is a clock, and you can see the corner of a cabinet in the upper right.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-15-2013, 12:20 AM   #2
Himcules's Avatar
pretty cool!
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-16-2013, 09:29 AM   #3
Herk7769's Avatar
When can I borrow it?
HAM CALLSIGN - KC3FFW
Old 05-16-2013, 09:58 AM   #4
AquaMan's Avatar
In your case this won't help, but I was outside early one morning before the dew burnt off, and while looking down the side of my camper, I could see the outline of every stud and cross brace in the wall. I have a pretty good stud finder also, that will detect the edges of studs and electrical wires. Never noticed the "dew effect" before though.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 05-16-2013, 11:26 AM   #5
RPAspey's Avatar
yeh, my intent was to trace the power cables so I wouldn't drill into one. I also wanted to "see" what else might be there. My stud finder showed the stud against the inside wall, but gave me an error at the spot where the "outside" stud is located. The camera helped me determine what was back there.
The FLIR camera is a neat tool for evaluating your heat loss on your home too.
Oh, at night, you can find those darn critters creeping around your garden too. makes it easy to stop veggie damage....if you get my drift
Old 05-16-2013, 11:26 AM   #6
RPAspey's Avatar
Herk, you're not too far away
Old 05-16-2013, 11:39 AM   #7
Herk7769's Avatar
Not so sure about that...
More than one person has told me I was "way out there..."
Old 05-16-2013, 11:50 AM   #8
RPAspey's Avatar
lol
Old 05-19-2013, 11:39 AM   #9
Do the campers with the laminated sidewalls even have studs. I have a 2304S in which I added shelves to the kitchen cabinets and could not seem to find a stud so I just screwed them to the wall. They are holding up well.
Bloomington MN
Rockwood 2304S
TV is a 2014 F150 5.0 V8 with Equal-i-zer
jwuertz is offline   Reply With Quote
Old 05-19-2013, 12:18 PM   #10
RPAspey's Avatar
I wouldn't know, but i know how to find out. The IR camera sees all just kidding, I'd like to know about laminated walls too.
